Normally, you just select mapped picture in the bump tab, choose you image, and voil Change bump strengh if need be, but that's about it. Use a filer if you want, you can use the "bump quantize" from "other filters", it prevents artifacts. The only other solution I see is to use the image offset parameters in this tab. The scale for this tab is in pixels, so values of 100 or greater are generally needed. All I can see.
I have two very high resoluton images that I am trying to use to create a model of the Earth. The color map is in .jpg and applies with no problem after a small wait. The second is in .png format and is the bump map. How do you apply the bump map so the heights are correct ? I know this is probably simple and that I am missing something. Any help would be greatly appreciated. Thanks Richard
