Sat, Feb 8, 11:21 AM CST
Subject: Applying a bitmap as a bump map
yossam ( ) posted Tue, 23 August 2005 at 2:01 PM ยท edited Sat, 08 February 2025 at 11:17 AM
I have two very high resoluton images that I am trying to use to create a model of the Earth. The color map is in .jpg and applies with no problem after a small wait. The second is in .png format and is the bump map. How do you apply the bump map so the heights are correct ? I know this is probably simple and that I am missing something. Any help would be greatly appreciated. Thanks Richard
wabe ( ) posted Tue, 23 August 2005 at 2:03 PM
What Vue version?
yossam ( ) posted Tue, 23 August 2005 at 2:04 PM
Vue Infinite
bruno021 ( ) posted Tue, 23 August 2005 at 4:26 PM
Normally, you just select mapped picture in the bump tab, choose you image, and voil Change bump strengh if need be, but that's about it. Use a filer if you want, you can use the "bump quantize" from "other filters", it prevents artifacts. The only other solution I see is to use the image offset parameters in this tab. The scale for this tab is in pixels, so values of 100 or greater are generally needed. All I can see.
yossam ( ) posted Tue, 23 August 2005 at 4:58 PM
There is no mapped picture in the bump tab. I have looked at everything believe me.
bruno021 ( ) posted Wed, 24 August 2005 at 12:14 AM
Oh, ok I see. When in the bump tab, control click the gray sphere, and you'll get to the function editor. ; There, click on an empty space near the " bump output", and this little red square appears. Now click the 6th icon on the left. And choose your image to apply as bump.
