Wed, Nov 20, 5:41 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 20 4:32 am)
Subject: Now Available at Lost in 3D - Davros for the P4 Male
LostinSpaceman ( ) posted Wed, 24 August 2005 at 2:41 PM · edited Wed, 20 November 2024 at 5:41 AM
Attached Link: http://www.lostin3d.com/
Davros for the P4 Male by Xantor Located in the Doctor Who Forum under his own sticky download thread! Free Membership Required for Access.
xantor ( ) posted Wed, 24 August 2005 at 3:00 PM
The Davros figure works in poser 6, so it probably works in poser 5, too, but you need the poser 4 male and his sweater for the file to work.
alt1701 ( ) posted Wed, 24 August 2005 at 3:10 PM
wow thanks this is great
xantor ( ) posted Wed, 24 August 2005 at 3:39 PM
I am glad you like it.
Redfern ( ) posted Wed, 24 August 2005 at 3:42 PM
WOW! That actually works amazing well! Here's a thought, try applying the texture to the P4 male based character named Dr. Morpheen, a freebie at RuntimeDNA. It has a variety of morphs to purposely create "ugly mugs". A few tweaks should approximate Davros' oddly shaped skull. Xantor, have you attempted to create a Tom Baker texture in a similar fashion? I know Cobalt years ago used the Poser 4 male to create a surprisingly effective 4th Doctor. If you can do with Baker what you've done with Molloy, you'll have legions of fans worshipping at your feet! Sincerely, Bill
Tempt the Hand of Fate and it'll give you the "finger"!
LostinSpaceman ( ) posted Wed, 24 August 2005 at 3:50 PM
I'll bow down to that idea! ;) I loves my Tom Baker Doctor!
xantor ( ) posted Wed, 24 August 2005 at 3:54 PM
I havent tried making a tom baker character yet. The davros texture was made using photos and trying to make the parts fit.
xantor ( ) posted Wed, 24 August 2005 at 4:23 PM
This is dr morpheen with the davros texture. You could get better results than this, it was just to try it to see how it worked.
LostinSpaceman ( ) posted Wed, 24 August 2005 at 4:32 PM
Very nice! What he really needs now is a nice 3D Eyeball prop for the middle of his forehead. I haven't been able to get the texture displaced enough to make the eye pop out yet.
Redfern ( ) posted Wed, 24 August 2005 at 7:06 PM
Well, color me impressed! This map really works! I shaped the nose differently from Xantor, emphasizing the bump and bulb. I also scaled the head slightly and used the taper dial. Instead of the sweater, I used the turtleneck. Davros wore a leather version of a labcoat with a high collar. Finally, I plopped him in my chair with the headgear. Actually, a simple blue sphere prop with bright highlights should do quite well. Wisher's mask had a kind of mechnical eyelid partially covering his cyber-eye while Molloy's was a simple sphere partially embedded within folds of tissue creating a kind of natural eyelid. Sincerely, Bill
LostinSpaceman ( ) posted Wed, 24 August 2005 at 7:40 PM
I'm thinking that Dork or Dr Morpheen just need a nice "BigBrain" morph to really do his bulbous head justice. I might work on that in Zbrush if I stay motivated long enough. ;) I found a cyber Eye prop in my runtimes that must be from your set Bill. I've got a Mimic clip animating him in the background right now or I'd fiddle with your props on him.
JHoagland ( ) posted Wed, 24 August 2005 at 8:17 PM
Very cool! That's really the P4 male? I never would have believed it! But, where are the Daleks? Davros was never seen without the Daleks around. :) --John
VanishingPoint... Advanced 3D Modeling Solutions
LostinSpaceman ( ) posted Thu, 25 August 2005 at 2:43 AM
Attached Link: http://www.lostin3d.com/Flash/Davros.html
You want Daleks? Watch this:
LostinSpaceman ( ) posted Thu, 25 August 2005 at 2:44 AM
PS for some reason my AVI to SWF converter cut's the sound off prematurely. SwishVideo the latest build.
xantor ( ) posted Thu, 25 August 2005 at 7:20 AM · edited Thu, 25 August 2005 at 7:22 AM
I have made a dalek, it is more like the older ones but not a specific show one, it is not available yet.
I wanted to make a big brain morph for the davros figure but I am not so good at making morphs, posers tiny scale doesnt help either.
I also realized after the figure was available that the turtle neck would look better for the davros jacket.
Message edited on: 08/25/2005 07:22
LostinSpaceman ( ) posted Thu, 25 August 2005 at 2:28 PM
Actually he didn't need a "Big Brain morph at all Xantor. Just Taper his head to about -20 and whala! Big headed Davros. I've updated the CR2 in the zip file online with the grey base color and the head taper settings.
LostinSpaceman ( ) posted Thu, 25 August 2005 at 2:29 PM
If you want I can swap out his Sweater for the Turtleneck as well.
xantor ( ) posted Thu, 25 August 2005 at 4:16 PM
I sent you a pm at lost in 3d about this.
LostinSpaceman ( ) posted Thu, 25 August 2005 at 7:21 PM
Your updated file is online with the readme file added. Now stop loosing my email address you big goof. ;)
xantor ( ) posted Thu, 25 August 2005 at 9:36 PM
ok The newer file has the turtle neck sweater and the grey base and the bases` shape has been fixed, too ( in the picture above you can see it is slightly wrong ). For the benefit of others reading the thread.
LostinSpaceman ( ) posted Fri, 26 August 2005 at 9:17 AM
Here's the image for the latest figure update:
LostinSpaceman ( ) posted Fri, 26 August 2005 at 9:56 AM
Oh, His head has a Taper setting of -20 in that latest image but you'll have to set it yourself if you want it that way. He comes in the zipfile with no taper setting.
xantor ( ) posted Fri, 26 August 2005 at 2:09 PM
That latest picture you showed has the base wrong still. This picture shows the fixed base.
LostinSpaceman ( ) posted Fri, 26 August 2005 at 2:35 PM
Hrm... that it does. Need to check my runtime I obviously loaded the wrong one.
LostinSpaceman ( ) posted Fri, 26 August 2005 at 2:43 PM
LOL! Nope runtime was fine. Just uploaded the wrong picture.
xantor ( ) posted Fri, 26 August 2005 at 2:53 PM
To get the eye and headpiece you could use the one from vanishing point. It seems a bit pointless to remake it when the vanishing point one is there already.
