Mon, Nov 25, 5:44 PM CST
Subject: Los Azahares
cedarwolf ( ) posted Wed, 24 August 2005 at 7:12 PM ยท edited Thu, 21 November 2024 at 1:11 AM
Y'know, I hate to complain about inexpensive props...but I bought Los Azahares from DAZ and I have yet to be able to get it to work on my computer. I've got an Athalon based system, 512MB of RAM, P5, and every time I try to use the prop it takes up to two hours searching for bmp maps and finally locks up the computer. I tried posting to the DAZ Nuts n Bolts forum but for some reason nothing is showing up there... Any suggestions?
nruddock ( ) posted Wed, 24 August 2005 at 7:28 PM
If your being asked to locate .BUM files, open the PP2 in a text editor and replace ".bum" with ."jpg"
(Or try using the P6 version)
Elusion ( ) posted Wed, 24 August 2005 at 8:27 PM
Hi! Los Azahares uses .bum files for bump maps Poser Artist/4. PP, Poser 5 and 6 use jpgs for bumps. You have two versions of Los Azahares in the Los Azahares Props Folder. One is for P4/Poser Artist, and the other, named: Los Azahares_P6 is for Poser Pro Pack, 5 and 6. If you are using Poser 4/Artist, you can convert the jpg's to bumps before you load the prop files. As the readme indicates, the textures are in: Runtime:textures:Moyra:Los_Azahares and all the bump maps end in _B (underscore B). If you are using a later version of Poser, you can just load the appropriate file, no need to convert anything. Hope this helps, Moyra
Stormrage ( ) posted Thu, 25 August 2005 at 12:40 AM
make sure you also have http://www.daz3d.com/shop.php?op=itemdetails&item=3514 this product and installed it. Lost azahares requires it to work.
cedarwolf ( ) posted Thu, 25 August 2005 at 8:59 AM
Yep, I've got the Chalet de Sevilla. I didn't realize that you could use P6 files in P5. No one has mentioned this up till now, as far as I know. I'll try the P6 version!
