Fri, Jan 24, 11:35 PM CST
Subject: character inj pose question
Foxseelady ( ) posted Fri, 26 August 2005 at 11:47 PM ยท edited Fri, 24 January 2025 at 11:35 PM
Okay here's the dilemma. I finnally have my character inj rem done, they work (woohoo giggles) only.....when inj she looks great and "floats" :0 when removed she looks like vicky; that is once you find her lol she flies away completely. Why is this and does anyone have a tip or solution to lend me? TIA
nruddock ( ) posted Sat, 27 August 2005 at 12:37 AM
Check the Hip and Body translation dials to see if they're set to something by your INJ pose. It's then a matter of tracking down what's responsible. Perhaps your could start with a list of the files you made.
Foxseelady ( ) posted Sat, 27 August 2005 at 2:18 PM
Okay sorry, I'm pretty new to this part of poser. I can check those dials that's understandable (I think) but what it would mean to me....I don't really know rof. Feeling a little red here. I wouldn't even know how to track down the responsible thing. Sort of hopeing there was an easy fix.....should have known better :0 It's only easy after it's done a few times right!! lol Thanks for trying I at least have a starting place now ;)
nruddock ( ) posted Sat, 27 August 2005 at 4:11 PM
You don't say how you made the INJ/REM poses, was it by hand or did you use a utility ?
The X, Y, and Z translation dials should be at 0.0
If they're not, you need to look at the INJ file and see if these channels are in it (they can just be removed).
You shouldn't have anything but morph channels in the INJ file.
Foxseelady ( ) posted Sun, 28 August 2005 at 12:18 AM
I created it with inj pose builder. I looked at the xyz (move up, sideways ext right) in the dials after inj and rem in poser andthey were 0. So I opened up the script file and read it in word pad. Although I'm not so sure what I am looking exactly at I could not see those files with numbers anywhere in them. Oh execpt the xyz scales were at 01 but I do have her scaled down is that okay or are those the ones that should be 0? I can't thank you enough for pointing me where I should be heading it's much appreciated.
nruddock ( ) posted Sun, 28 August 2005 at 4:07 AM
Ok, as you did use scaling, then those channels should be present.
Short of taking a look at the file itself, you could post screenshots before and after applying the INJ pose, as this may provide a clue to what's going on.
