Fri, Jan 10, 11:09 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 9:07 am)
Subject: Poser's dirty little secrets...
RKane_1 ( ) posted Fri, 26 August 2005 at 8:56 PM · edited Fri, 10 January 2025 at 11:05 AM
Okay, well maybe not dirty but still items of information that not everyone knows. Recently there was a post with information on how to lock morphs that I had no idea about. Are there some other handy suggestions and hints on how to do some simple yet helpful things that maybe not everyone knows? If so, can you explain them or provide links to more info about them? Thank you!!
Kalypso ( ) posted Fri, 26 August 2005 at 11:20 PM
Site Admin
Well, my favourite in manipulating large scenes is bringing in a ball prop, open the hierarchy menu and drag and drop all figures/props on the ball. Then you can rotate, scale, drag do anything to the ball and the whole scene will be affected. You can have multiple groups like that. Oh, and the mini-me python script that comes with Poser 6 is a hoot! Everything in your scene is exported as obj, retaining all materials and texture calls, and reimported at a fraction of the original size - nice way to clean up a large scene before rendering and alleviate file size due to many morphs. You can, of course, scale this. It's given the name yowza.obj by default so if you want to keep it you'll have to save it or it gets overwritten with the next one.
kuroyume0161 ( ) posted Sat, 27 August 2005 at 12:46 AM
Well, my favourite in manipulating large scenes is bringing in a ball prop, open the hierarchy menu and drag and drop all figures/props on the ball. Then you can rotate, scale, drag do anything to the ball and the whole scene will be affected. You can have multiple groups like that. I wonder who developed this as this something of a well-known (if not expected) trick in Cinema 4D. It has a 'Null object' specifically for these purposes into which you drop other objects for doing similar things. It is also very useful for controlling rotations - and avoiding gimbal lock. I know that there is a trick similar to this in Poser for doing the same.
 -- Bjarne Stroustrup
momodot ( ) posted Sat, 27 August 2005 at 8:25 AM
Kalypso, thanks!
EnglishBob ( ) posted Sat, 27 August 2005 at 9:49 AM
Let's see now... Hold Alt while clicking on a dial to return it to its default value. Hold Alt while clicking on a memory dot to clear it. Hold Ctrl while dragging the mouse to make the current tool affect the camera instead of the selected figure. Don't eat the yellow snow. :)
xantor ( ) posted Sat, 27 August 2005 at 10:05 AM
The sensitivity in the dials can be changed to a higher or lower number. Lights can have shadow maps that are 2048 if you change the settings for the map size like the picture, it makes it easier to change the light map size.
Kalypso ( ) posted Sat, 27 August 2005 at 10:07 AM
Site Admin
:)momodot, glad you found something useful! Let's see, here's a cool one I learned from Anton a long time ago. Hold ALT and click on the wireframe figure in your interface - if your display is too large you may not be able to see it. There are many different ones to choose from. Poser 4 came with the girl on the trapeze as default. I think P6 has the head, my favourites is the guy lying down! Nothing terribly useful in that other than its being aesthetically pleasing ;)
Netherworks ( ) posted Sat, 27 August 2005 at 10:40 AM
I'm kinda woozy and need a nap but what I can think of off the top of my head: Using Point At on the figure's eyes (works with all millennium folks) to point at either the Main Camera or a ball prop. Parenting Lights to a ball to rotate all them uniformly at once. In fact, you can also parent infinite lights outside of Poser with some creative work to a ball and when loading the ball, all of the lights come in too. There's more but... Zzzzzzzzzzzzzz
RKane_1 ( ) posted Sat, 27 August 2005 at 10:49 AM
Wow! Cool guys! Keep them coming! I am learning a lot! What other little secrets are there that you wish you'd known sooner?
geoegress ( ) posted Sat, 27 August 2005 at 11:51 AM
bookmarked :)
Aeneas ( ) posted Sat, 27 August 2005 at 12:45 PM
no credit for me. In case Poser refuses to show thumbnails: http://www.dtigerwoman.com/tutorials/p5sr4.shtml
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
zollster ( ) posted Sat, 27 August 2005 at 1:17 PM
i was playing with the wireframe like post7 but now it disappeared. how do i get it back? i've tried relaunching to factory state
SWAMP ( ) posted Sat, 27 August 2005 at 3:45 PM
You can turn off highlight body parts by going to runtimeprefsPoser(configuration settings) and double click to open in notepad. Change HILITE_BODY_PART 1 to HILITE_BODY_PART 0 and save. When rendering to a (larger) new window part of the progress bar gets covered up. Drag it to a location where it can be viewed completely, then under General Preference set "Preferred State". Now it will always be in that new location when you render. Do the same as above for other windows (like Python Script and Joint Editor) to change their default location. SWAMP
PabloS ( ) posted Sat, 27 August 2005 at 5:54 PM
great thread!
shedofjoy ( ) posted Sat, 27 August 2005 at 7:20 PM
Usefull little thread. But i can't remember how to change the background colour of the P6 Interface (As in Post 7)? does anyone know???
Getting old and still making "art" without soiling myself, now that's success.
LostinSpaceman ( ) posted Sat, 27 August 2005 at 10:06 PM
As a matter of fact, Yeah. CTRL + Left Click the Background while the Paint Tool is selected brings up the Color Palette for your Background. Left Click on the Background while the Paint Tool is selected brings up the Color Gradient Tool for your Background.
shedofjoy ( ) posted Sun, 28 August 2005 at 6:54 AM
thanx Mizrael
KarenJ ( ) posted Sun, 28 August 2005 at 9:41 AM
Hold down ALT and double-click on either the Editing Tools or Document Display Style wording to toggle the alignment between horizontal and vertical.
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
SteveJax ( ) posted Sun, 28 August 2005 at 11:49 AM
Is that for Vertical Display monitors Karen?
semidieu ( ) posted Sun, 28 August 2005 at 1:18 PM
Great threads ! Thanks for all the tips !
EdW ( ) posted Sun, 28 August 2005 at 2:46 PM
Selecting a group of frames in the animation palette and holding "ALT" key down while dragging the frames to a new location will copy the selected frames to the new location. Setup Room When typing in the name of for a new bone, don't forget to hit the enter key or Poser won't change the name... the ole non standard dialog box thing.
Alisa ( ) posted Sun, 28 August 2005 at 11:08 PM
Great tips - bookmark!
Cheers,
Alisa
RETIRED HiveWire 3D QAV Director
Bobasaur ( ) posted Mon, 29 August 2005 at 12:36 PM
BM
Mason ( ) posted Mon, 29 August 2005 at 6:07 PM
ctrl (or is it alt) click on a camera icon to reset that camera view. Ctrl 1 thru 9 are the preview presets. Load a ball, make it a child of the head, place it at 0.0,0.8,0.5, point each eyeball at the ball and hide the ball. Now slide the ball up or down and side to side to make aiming eyes a lot easier. On any parameter window you can hit ctrl-c to copy all dial settings and ctrl-v to paste them. This way you can copy magnet settings, face settings etc from one figure to another.
Casette ( ) posted Tue, 30 August 2005 at 6:45 AM
BKMRK ;)
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
