Fri, Jan 10, 5:01 AM CST
Subject: Bryce to Poser
yllib ( ) posted Tue, 30 August 2005 at 7:14 AM · edited Fri, 10 January 2025 at 12:05 AM
I render a water scene in Bryce, import it into Poser. Then I add a figure in poser and try to have it go partly below water, but it wont it still shows figure below water. If i try to export figure in Bryce it works only textures are wrong. Like to work in poser. Help
Hawkfyr ( ) posted Tue, 30 August 2005 at 7:30 AM
Hi yllib Have you tried applying the water texture to the groundp plane (or 2D square), rather than importing it as a backdrop?(I'm assuming you are importing the image as a background image). Tom
“The fact that no one understands you…Doesn’t make you an artist.”
yllib ( ) posted Tue, 30 August 2005 at 8:16 AM
Yes I am importing the image as a background how do I apply the water texture?
pakled ( ) posted Tue, 30 August 2005 at 11:26 AM
Paging Dr. Geep! Paging Dr. Geep! (he has a tutorial on backgrounds, taught me almost everything I know. I seem to remember texturing the floor with a jpg (in Poser) and applying that to a square..or something. The few times I've done it, it gets stretched out. But it can be done. Bryce makes great backgrounds (but so does Mojoworld, but that's another topic..;)
nickedshield ( ) posted Tue, 30 August 2005 at 1:41 PM
If you really like to experiment go over to runtimedna.com and get the IC3 set. Then, look at the texture size and make yours to match. What I like is stacking ground planes and applying different textures to different shapes. But then again, I like to play.
