Fri, Jan 10, 7:27 AM CST
Subject: Annoying P6 problem...
DocMatter ( ) posted Sat, 03 September 2005 at 1:09 PM · edited Fri, 10 January 2025 at 7:09 AM
I've noticed lately that some of my .pz3 files have been losing content. At first, it only happened if P6 locked up and I closed it with ctl+alt+del. When I reopened the file, most of the content was missing (i.e. lights, textures, and some figures). But now its happening with files that I normally save and close. I open them up and they show up in wireframe mode, no lights, very few if any textures, and some of the figures are missing. Is this happening to anyone else? I have 1 GB RAM and a 1.8 MHz P4 processor and have SR1 installed.
TrekkieGrrrl ( ) posted Sat, 03 September 2005 at 3:16 PM
Do you save them as compressed files? And do you save them with external morphs? If so, they WILL get wonky if the files are moved later.
Dizzi ( ) posted Sat, 03 September 2005 at 4:43 PM
Attached Link: http://www.runtimedna.com/mod/forum/messages.php?forum_id=43&ShowMessage=154576
This can happen with standard MAT pose files, that leave unconnected nodes in the material room. After applying such a MAT pose, use the "Remove Detached Nodes" (press shift while clicking, to apply it to all materials at once). After that the file should be completely written to disk.
CauriBlackthorne ( ) posted Sat, 03 September 2005 at 4:47 PM
This happens in P5 too
Jackson ( ) posted Sun, 04 September 2005 at 1:54 PM
Something similar happens to me with P6 SR1, but it's not after saving; it's after a render. After about an hour or so working in a scene--without adding or switching anything--P6 will begin to slow substantially. After that amount of time, I will have done several test renders. Then, all of a sudden, I do another test render, come back to the preview window, and almost everything is gone! Some of the scene props will still be there and maybe a hair prop, but everything else is gone. The characters are still listed in the drop-down but they are not there. Without saving, I check the file sizes of the pz3 and pmd. What used to be 7 or 8 meg files are now about a half meg in size. (I had done several saves before this happened.) Apparantly, P6 was saving the files while it was destroying them. NOTE: Each time the scenes were small. Two lightly injected mil characters and a few scene props. I've learned not to do anything larger in P6. It happened three times to me. I've had to completely re-do everything. I've never had this happen in P6 before SR1. Neither has it happened in P5, P4, or P4 with ProPack. I have a dual-pentium zeon, 1 gig o' ram, 350 gig HD machine.
