Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 11 2:56 am)
"Out of memory" is just Poser's way of telling you it ran into something it can't cope with. Usually has nothing to do with memory. This sounds like corrupted .rsr files. You can safely delete a .rsr file (except for Poser.rsr in the root Poser folder!). You'll lose the thumbnails in the libraries, but, as you say, you can recreate them fairly easily. So if a figure refuses to load, just quit Poser, delete the associated .rsr, start Poser again and retry. Save back to the library to create a new .rsr
"You'll lose the thumbnails in the libraries, but, as you say, you can recreate them fairly easily." It's generally only the geometries .rsrs that get corrupted. I don't recall ever having one of the preview ones go bad, but true you can delete them. To prevent the problem, just change the attributes of the files to read only. Of course, you have to remember to do it to newly added files. From a (on Windows) command prompt in the geometries folder the command: attrib +R *.rsr /s will set it for all rsr files in all subdirectories. You should only need to delete one if you modify the .obj file, for instance changing the UV mapping.
Good suggestion nickedshield, plus, there are two references, one at the top and one near the bottom - both need to be changed - same applies to props as well. Though if so many are giving errors though and the geometries weren't moved, I'd guess it's more likely corruption, possibly a problem with the disk. OTOH, with Poser you never can tell.
I have Poser 4.01 and have been installing all of the files that I've been downloading. I have been moving everything to places that I like them and all of a sudden half of my figures will not load, giving me the following error message... Cannot Open Runtimegeometries"file" Cannot Open Resource file Runtimegeometries"file" You are out of memory When installing all of the figures I would bring them into poser and resave them with the "Add New Figure" button so that they previewed more the way I wanted them to. I moved cr2 and rsr files around to folders that fit me better. Keep in mind that I did not disturb the Geometry files, they were left in tact, the way they were downloaded. Please, if anyone knows how to fix this, please let me know...I've put a lot of work into organizing and it would be a shame to start over. Btw, for reference, I am not out of memory as I doubt that Poser could use 2 Gigs of memory even on its worst days. Please help.
