Fri, Jan 24, 1:58 AM CST
Subject: water tutorial
satfj ( ) posted Wed, 07 September 2005 at 6:55 AM · edited Fri, 24 January 2025 at 1:56 AM
any tutorial as to how to animate water as when a boat sails by? Thanks
RaysOfLight ( ) posted Wed, 07 September 2005 at 7:04 AM
there's a link to this http://sorenworlds.netfirms.com/Wake/wake.htm in the backroom, but if you're wanting to animate it, i'd have to say i haven't got a clue :)
wabe ( ) posted Wed, 07 September 2005 at 7:59 AM
What version of Vue? For Infinite there is a tutorial in the manual. Making an ocean.
bruno021 ( ) posted Wed, 07 September 2005 at 11:54 AM
I think he means that he wants the trail of the boat animated. I have no idea.
wabe ( ) posted Wed, 07 September 2005 at 12:12 PM
I would try to combine two or even more terrains that are animated in the way the manual describes it. Wether it is successful is another thing. Would be interesting to see!
RaysOfLight ( ) posted Thu, 08 September 2005 at 1:18 AM
i suppose the best way to do something like that would be to set up a function through which water particles change colour and texture as they interact with the boat, therefore creating the illusion of a trail, but i'm guessing that vue doesn't really focus on that type of processing and even if it did, i'd still have no idea how to do it :p
wabe ( ) posted Thu, 08 September 2005 at 1:54 AM
Only the function wizard DBurdick would know. He did a very very good tutorial about foam for water at the beach. Maybe this concept can be used because it has a sort of interaction between beach and water material - when i understood it right.
Becco_UK ( ) posted Thu, 08 September 2005 at 10:36 PM
Attached Link: http://www.nextlimit.com/realflow/index.html
Alternatively, you may wish to consider using the RealWave function the RealFlow3 demo from Next Limit Technologies. I use a full licenced copy but understand the demo is functional (for non commercial work). My licenced copy will output a series of meshes in .obj format making it useful for programs that do not load RealFlow binary sequences. Perhaps the demo has this output too?
bruno021 ( ) posted Fri, 09 September 2005 at 6:23 AM
@ Becco UK: realflow looks amazing, but it only works on Win Pro versiosn. What a shame. But then I checked the price tag, and thought it didn't matter after all!!!!
Becco_UK ( ) posted Sun, 11 September 2005 at 2:51 AM
bruno021: Yes I use RealFlow3 on a system with XPPro but for those without XPPro it may still be worth giving the functional demo a try. For close up work I think a shaped mesh is preferable to flat planes with a bump map. I agree RealFlow is relatively expensive but there is little else with similar capabilities. The attached image is a current project that includes a RealWave surface.
bruno021 ( ) posted Mon, 12 September 2005 at 1:11 AM
Looks terrific. Do you think the demo will work on XP Home ed?
