Attached Link: http://www.weirdass.net
Quoted from a Curious Labs technical support email on this subject: The missing genital switch needs the hipnogen object in a runtime/geometries folder that was missed. Runtme/Geometries/Poser4Figures/create a folder named "P4NudeMphMan" and copy the file from P4NudeMan called "blHipNoGen.obj" to the new folder. Try the above I cannot open the CR2 to be sure it is the proper path the above solution is for windows but the folder arrangement is most likely Identicle. Tech PS The Poser 2 figures work with the genitals on or off. Make sure you did a clean (OS base extention set) install and also allow Propack to update the Metacreations version of Poser 4 do not patch. Also remove the old folder (BACK UP CUSTOM STUFF) before installing Poser and PPP(propack)Attached Link: http://www.weirdass.net
Don't ask me, this is verbatim from the email that curious labs tech sent me. I'm just passing it on. MitchAttached Link: http://www.weirdass.net
Imagine if your doing a daily comic strip and half of your cast lost their hips... now thaat is scarrrryThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I've been trying to find a solution to the missing p4 male hip in PPP. I've tried Genitals on and off with no luck. Has anyone found a solution?
