Sat, Feb 8, 5:09 PM CST
Subject: Problem using populate in Ecosystems!
GAM3d ( ) posted Mon, 12 September 2005 at 12:31 AM ยท edited Sat, 08 February 2025 at 4:58 PM
Hi, I was working on a Scene, ive created the terrain and then applied a complex material with ecosystems. But now when i press "populate" in any of the ecosystems the soft performs a calculation but nothing happens, 0 instances... Im doing something wrong? what can it be? Thanks in Advance. Bill.
dburdick ( ) posted Mon, 12 September 2005 at 1:14 AM
Either: 1. the object(s) you chose to populate on the ecosystem base object are too large 2.the presence of foreign objects is preventing the placement of your eco-objects if you checked "Decay Near Foreign Objects) 3. The overall density you selected is too small To fix this: 1. scale down the size of the objects you want to populate 2. uncheck the "Decay near foreign objects" box or lower the decay percentage value 3. Increase the density
Sabra ( ) posted Mon, 12 September 2005 at 5:26 AM
Either that or the terrain you wish to populate is too small
GAM3d ( ) posted Mon, 12 September 2005 at 9:40 PM
Still not working. I load a basic material, then add ecosystems (simple trees) and the terrain is populated well, i copied all the setting. I load my material, but this time the settings are not working. My material is a complex mix with various sublevels (a total of 4 ecosystems). Another ideas please please?
lanaloe77 ( ) posted Tue, 13 September 2005 at 1:05 AM
#4
It happens to me all the time but I don't know why. I start over and change my workflow to rid myself of the bug.
The ecosystems have a couple of bugs but there are not as bad as procedural terrains.
wabe ( ) posted Tue, 13 September 2005 at 2:59 AM
Is there any chance to have a hand on the material that does not seem to work? So that we can look into it and understand better what you have done.
GAM3d ( ) posted Wed, 21 September 2005 at 11:52 AM
yes, but how can i upload the material? the system only accept gif, jpg and txt? if you want, i can send it by mail. thanks in advance.
