Sun, Jan 26, 12:12 AM CST
Subject: Strange P6 Problem
barrowlass ( ) posted Tue, 13 September 2005 at 8:21 AM ยท edited Fri, 24 January 2025 at 5:15 PM
A week or so back I posted a query regarding Parse Errors. I have P6+Content Updater. I looked at the Prefs xml and couldn't see anything that could be causing the problem - also looked thru all my folders in both my runtimes P6/P5 to make sure.
Like most people when starting with Poser I use edit>General Preferences to get the startup I want, in my case - no figure and with different elements in certain locations in the screen.
On checking Prefs folder I discovered the attached item - ringed in the example and suspected that this maybe the cause of the Parse Error problem. I deleted the item with the P6 icon and everything is ok in that respect. The only thing is, I have to re-set up my favoured UI each time I open P6 which is something of a pain.
Any help would be welcomed. Would installing SR1 help?
Thanks
My aspiration: to make a decent Poser Render I'm an Oldie, a goldie, but not a miracle worker :-)
Gallery
Freebies
Music Vids
Angel1 ( ) posted Tue, 13 September 2005 at 8:34 AM
....Now Bring Me That Horizon....
Send IM | Gallery
bevans84 ( ) posted Tue, 13 September 2005 at 9:00 AM
After setting up your preferred state and saving it as your preferred state, is preferredState.pz3 being saved in your "prefs" folder? If not, I would try "save as" into that folder after insuring that compressed files are turned off. SR1 couldn't hurt.
barrowlass ( ) posted Tue, 13 September 2005 at 9:05 AM
Thanks will try that - never had this problem with P4PP/P5! However, the pic shows the contents of my prefs folder so I don't know what else I can do.
Gallery
Freebies
Music Vids
xantor ( ) posted Tue, 13 September 2005 at 10:01 AM
If you have file extensions switched off in windows you should switch them back on. Poser makes a pz3 called preferred state when you set your own preferences and that is probably the file that you deleted. (It will be a pzz if you have file compression on)
barrowlass ( ) posted Tue, 13 September 2005 at 10:11 AM
Hi Xantor - it is a pz3 file. I haven't deleted it this time, just set my preferred state, saved it to prefs folder with the name "1" as a sort of test. I don't have file compression on. I'll see if this will solve the problem. When I do get a parse error warning, if I click OK, I can carry on working - P6 doesn't shut down. I'd just like to have things running "normally" - wouldn't we all? ;-)
Gallery
Freebies
Music Vids
xantor ( ) posted Tue, 13 September 2005 at 11:05 AM
To save it to work as the preferred state it will have to have the name preferredstate.pz3 so that poser knows what it is.
barrowlass ( ) posted Tue, 13 September 2005 at 11:07 AM
ok thanks for that, Xantor
Gallery
Freebies
Music Vids
