Thanks will try that - never had this problem with P4PP/P5! However, the pic shows the contents of my prefs folder so I don't know what else I can do.
My aspiration: to make a decent Poser Render I'm an Oldie, a goldie, but not a miracle worker :-)
Hi Xantor - it is a pz3 file. I haven't deleted it this time, just set my preferred state, saved it to prefs folder with the name "1" as a sort of test. I don't have file compression on. I'll see if this will solve the problem. When I do get a parse error warning, if I click OK, I can carry on working - P6 doesn't shut down. I'd just like to have things running "normally" - wouldn't we all? ;-)
ok thanks for that, Xantor
Like most people when starting with Poser I use edit>General Preferences to get the startup I want, in my case - no figure and with different elements in certain locations in the screen.
On checking Prefs folder I discovered the attached item - ringed in the example and suspected that this maybe the cause of the Parse Error problem. I deleted the item with the P6 icon and everything is ok in that respect. The only thing is, I have to re-set up my favoured UI each time I open P6 which is something of a pain.
Any help would be welcomed. Would installing SR1 help?
Thanks
Gallery
Freebies
Music Vids
