Thu, Feb 6, 10:05 PM CST
Subject: What size do you start YOUR projects?
RodsArt ( ) posted Tue, 13 September 2005 at 7:11 PM · edited Thu, 06 February 2025 at 10:01 PM
The reason I ask this is for comparison of large VS small start-up projects. IMHO the larger you start, the more detail and chance of revision and fine tuning. So....to kick it off..... The smallest I usually start with is approx 1500w X 1000h. Typically 3000w X 2000h. Have also doubled that on occasion, yet it takes lots of planning & patience. Most times those end up multi layered compositions. Newbie Questions welcome, C'mon Lurkers!!
___
Ockham's razor- It's that simple
aprilgem ( ) posted Tue, 13 September 2005 at 7:35 PM
I do some of mine at about 12" across and 8" down, 300 dpi -- big enough for a book cover wraparound. If it's just a front cover, then I do it at 5.5" x 8", again 300 dpi. For the screen, when I set up the Bryce scene, that translates to maybe about 275 x 400 pixels (actually, bigger than that, but I'm too lazy to do the math; so long as it's the same aspect ratio, I'm good) for the front cover and about 900 x 600 pixels for the wraparound. Um. What does VS mean?
Zhann ( ) posted Tue, 13 September 2005 at 8:15 PM
800x600 for all initial stuff, then I move it up in size, but it really depends on how much detail I want to fool with if it's not going to be a closeup or detailed image...
Bryce Forum Coordinator....
zollster ( ) posted Tue, 13 September 2005 at 8:28 PM
as big as my pc will let me which is about 9000px X 6750px for bryce and 5000px X 4000px for poser- sometimes its 4000px X 3500px depending on poser's mood. i do it that big cos i find it easier to change bits in post
ddaydreams ( ) posted Tue, 13 September 2005 at 8:35 PM
2400* 1600 pixal To make faster changes then 6000*4000 for final.
Frank Hawkins/Owner/DigitalDaydreams
Frank_Hawkins_Design
Frank Lee Hawkins Eastern Sierra Gallery Store
My U.S.A eBay Graphics Software Store~~ My International eBay Graphics Software Store
Sans2012 ( ) posted Tue, 13 September 2005 at 8:54 PM
I start small like 1200 by 820 or something then make it bigger if I need too. Its a lot better to work small, especially if you have a lot of objects in the scene.
I never intended to make art.
pakled ( ) posted Tue, 13 September 2005 at 9:48 PM
size matters not..;) 800x600, because it is the limit of my patience..;)
tjohn ( ) posted Tue, 13 September 2005 at 11:25 PM
1024X768, my screen resolution, unless I want a different orientation. But the height is usually 768.
pauljs75 ( ) posted Tue, 13 September 2005 at 11:52 PM
It depends on what I'm doing it for and how long I'm willing to wait. I'll probably start out with a 640 x 480 in Bryce to get a rough idea. If I'm doing it for the screen, it'll go up to 1024 x 768 for a final render. If it's for print, I'll kick up the largest dimension to 3000 or so for 300dpi images that will fit on a typical piece of paper. If it's something simple for a web interface or icon (usually buttons or whatever), then I'll actually go smaller. Probably with the largest dimension around 400 or so. I'd probably try more fancy stuff (at decent resolutions too), but I still don't have the computer for it yet (at least with my level of patience). Thus I tend to do more modeling than rendering.
Barbequed Pixels?
draculaz ( ) posted Wed, 14 September 2005 at 4:08 AM
the size of my project is bigger than yours :P
Flak ( ) posted Wed, 14 September 2005 at 4:19 AM
I tend to start off at about 850x600 (the max recomended setting for Bryce on my pc) for the early stuff, but then my early stuff is mainly just boxing out and adding models as I do them. As I get closer to the end I'll up its size though to get a better feel for how it'll look. Final renders are about 2500-3000 pixels across-ish, depending on lighting rigs ;)
Digital WasteLanD
pumecobann ( ) posted Wed, 14 September 2005 at 4:31 AM
In Bryce, just the standard 540X405 for testing, 'cause the smaller the size...
...the quicker the render!
Len.
(Then I take a bucket of sand, and count the grains until a full-size image renders).
The wait can be horrific, but the outcome can be worse - pumeco 2006
Gog ( ) posted Wed, 14 September 2005 at 5:21 AM
I usualy start at 800x600 then do the final render only at a larger size, ready for post work. I get the impression from the answers that some folk would say the final render is the start of the project (those that are talented in post work :) ), while for others the render is pretty near the end.
Toolset: Blender, GIMP, Indigo Render, LuxRender, TopMod, Knotplot, Ivy Gen, Plant Studio.
Incarnadine ( ) posted Wed, 14 September 2005 at 6:36 AM
1600x820 (no particular reason, just like the aspect)
dan whiteside ( ) posted Wed, 14 September 2005 at 7:50 AM
I'm in the 800x600 crowd, as well 'cause I'm just lazy (and it's the Max size for the rendo challenge!)
Swade ( ) posted Wed, 14 September 2005 at 7:51 AM
I Always start of aT 800 X 600. Final render is always 1024 X 768 or larger.
There are 10 kinds of people: Those who know binary, and those who don't.
A whiner is about as useful as a one-legged man at an arse kicking contest.
scoleman123 ( ) posted Wed, 14 September 2005 at 8:21 AM
i start out as a 900 x 675 at 72 DPI do all my modeling and put the scene togather. then i render at 3600 x 2700 at 300 DPI
 facebook.com/scoleman123
FranOnTheEdge ( ) posted Wed, 14 September 2005 at 8:23 AM
It's not what I start at, it's what kills the computer later, and at the moment it's global shadows.... wail!!! and it's 1200x899 today.
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
CrazyDawg ( ) posted Wed, 14 September 2005 at 3:19 PM
I start out at the default setting on bryce then move it up to 800x600 the closer i get to the finish. If i want to adjust anything in the wip i go down to 640x480 just to make that adjustment. I also use the zoom in most times now which saves having to change resolution size.
I have opinions of my own -- strong opinions -- but I don't always agree with them.
jfike ( ) posted Wed, 14 September 2005 at 9:33 PM
I start at my working resolution of 1600x1200 on my desktop and 1400x1050 on my notebook. Then I adjust the render from default to premium (or use the spot render) depending on the complexity of the scene.
Dann-O ( ) posted Thu, 15 September 2005 at 8:07 AM
I start out at 1000x600 I like a letterbox look. I then bump it up a bit to 1200x720 for a full screen shot. I don't do print so I don't have a reason to go much bigger.
The wit of a misplaced ex-patriot.
I cheated on my metaphysics exam by looking into the soul of the person next to me.
SevenOfEleven ( ) posted Sat, 24 September 2005 at 12:32 AM
1024x768 Any bigger and people will complain about scrolling around to see stuff. Hear that a lot with my 2d stuff.
Incarnadine ( ) posted Sat, 24 September 2005 at 7:45 AM
That's why I downsample a copy of the final 16x12 tif file to jpeg for upload. Only thing I have found is that windows viewer in XP doesn't always like LZW compressed tif files. Makes errors in it's display of them. I use ThumbsPlus to do my image library functions so it's not much of an issue for me though.
