Like I said, the second image was made by loading the scene file. The material settings are exactly the same- all I did was open the scene and render it. There should be no need to check the specularity or anything else... how would they get changed in the first place? --John
VanishingPoint... Advanced 3D Modeling Solutions
I sent an e-mail to e-frontier to see if they can replicate this issue. We'll see what happens. --John
I played with these for two hours, changing all the settings I could think of, and as far as I can see, it just doesn't work. The reflection map works fine on it's own, the transmap works fine on it's own, but use reflection map with transmap in Poser 6 and it doesn't work. It works fine in Poser 4. I haven't tested in Poser 5 yet because I don't feel like re-installing it.
Your specialist military, sci-fi, historical and real world site.
Nope, I followed the same steps as John. Clean open of Poser, load Vicky, load catsuit, conform, add MAT file, and render. And the transmap doesn't work, because the reflection is being applied to the areas where it is transparent. I am getting exactly the same image as John, and I am on two different machines.
That is not the problem here. It has nothing to do with the lighting. I have deleted all the lights in the scene and created new ones just to check. The problem is with the interaction of the transmap and the reflection map. Load up Vicky, a catsuit, and apply any texture to the catsuit that uses a transmap. Then add a reflection map. As soon as you add a reflection map, the effect that John showed in the pictures above on the right happens. But this does not happen in Poser 4.
Making the assumption that the Material Room screenshot is the "before" one.
It looks like the problem is that the Specular_Color is being set to white when the file get reloaded.
Try disconnecting the map from "Specular_Color" (keep it set at black) and set "Specular_Value" to 0.0, save, reload, and see if it makes a difference.
(Getting highlights on transparent areas is a classic P4/PP PITA)
Have you tried using "Ignore Shader Trees" and using the "Simple" Material Room view to set things up for the P4 renderer.
The screenshot is the material room before and after the render, it doesn't change. The specular colour stays black. The big problem is that the product works in Poser 4 but not in Poser 6. We have sent an e-mail to e-Frontier to see if they know what is going on. Has anyone ever managed to render a reflection map with a transparency map in Poser 6? If someone else has managed to get this right we could look at their setup to see what the problem is.
I opened the scene again in Poser 6 (the same scene I saved in the previous step). This time, I went to Render > Render Settings, clicked on the Poser 4 tab, and checked all of the options, from "Anti-Alias" to "Ignore Shader Trees". I then rendered the scene... and it is CORRECT! Even the shadows are colored correctly!
So, nruddock's suggestion worked. :)
However, the FireFly renderer still renders the image incorrectly. Adjusting any settings gives the same results as the image to the right, in my first posting. I tried using the Auto settings, the Manual settings, and even tried adjusting things like Texture Filtering... though this shouldn't be necessary- the render settings should be saved with the scene file.
So, the issue may be caused by something in the shader nodes.
As a side note:
This is probably a "classic" issue because many material settings have the "transparency falloff" set to 0.6, which causes the material to be almost, but not quite transparent. To be fully transparent, the "transparency falloff" must be set to zero.
--John
Message edited on: 09/07/2005 23:14
Just as a follow-up: I have sent a zip file of files to the tech support people (with full instructions) to they can duplicate this issue. The tech also mentioned that this issue may already on the list of issues to be fixed in Service Pack 2. --John
