Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 06 11:30 am)
There are two remove bang pose files included, and each works only with one of the two hairs supplied. One just says "remove bang" which is for the comforming hair figure that is loaded from the Figures library. The other one (which is all the way at the bottom in the pose files) says "remove bang_Universal" which is for the hair prop loaded from the hair library. SWAMP
Im sorry; you may not have that file. I forgot that the Hr2 hair prop is a separate download that contains the extra pose files. So if you dont have that file I now assume you are using only the character (Cr2) version of that hair. Mine works fine, BUT you must be sure that the hair is selected when you apply the remove bangs pose file. When it hasnt worked, I saw I had something else selected like the head, neck or eye (which is easy to do, since that hair hangs down over everything). SWAMP
I take it that it is supposed to remove the hair part that hangs down in front of the face? I can't seem to get it to work at all. Has anyone else had this happen and is there any way of fixing it? I love the hair but would like to render without that one part of hair.
