Wed, Jan 8, 10:38 AM CST
Subject: FOOTPRINTS
Brog28 ( ) posted Thu, 15 September 2005 at 8:19 AM · edited Tue, 07 January 2025 at 1:32 PM
i am making a scence and i've ponder how i could make footprints with or without shoes either one would be nice. Cant think of object that could do it anyhelp or if u have a footprint obj. that would be great thx
TheBryster ( ) posted Thu, 15 September 2005 at 9:25 AM
Forum Moderator
Try using an arched shape maybe like a church window or door. Boolean it to your ground or terrain/snow. The arch would be a negative and would not appear in the ground leaving only its shape...aka footprint.....I'm thinking you'd need 2..one for the heel and a longer, more pointed one for the sole......
vasquez ( ) posted Thu, 15 September 2005 at 9:28 AM · edited Thu, 15 September 2005 at 9:29 AM
you can use terrains. Just import a scanned image of your feet or of your shoe. then abjust a bit the image in greyscale.
it should be easy (i think)
let me know
vasq
Message edited on: 09/15/2005 09:29
rickymaveety ( ) posted Thu, 15 September 2005 at 10:23 AM
Or, look for a black and white footprint gif or bmp (I may have one you can use), create a new bmp using it to create a walking pattern. Gausian blur the hell out of it. Resize it to 512x512 (just keep a mental note of the original proportions) and import it into Bryce to use as a terrain.
Could be worse, could be raining.
rickymaveety ( ) posted Thu, 15 September 2005 at 10:47 AM · edited Thu, 15 September 2005 at 11:01 AM
Here's one I did. It took me all of two minutes. You are welcome to use it if it will work for you. Just size the end terrain to be 2:1 or longer to make the feet look less chubby. You can also make it even more realistic by changing every other footprint ... mess them up a bit more so that no two are exactly the same.
Message edited on: 09/15/2005 11:01
CrazyDawg ( ) posted Fri, 16 September 2005 at 1:06 AM
i saw a tut somewhere about this...for the life of me i can't find the site it was on. I do remember the person said he went to a beach that had firm sand, walked on it for a few steps then took a photo of the footprints. he then imported the image into PS and made a greyscale from it then imported the greyscale image into bryce terrain editor...now this is going from memory so i hope i got it correct for you..
I have opinions of my own -- strong opinions -- but I don't always agree with them.
Brog28 ( ) posted Fri, 16 September 2005 at 9:43 AM
thx for all ur help going to make the pic this weekend i hope so check it out
