Sun, Jan 26, 4:36 PM CST
Subject: Dynamic Cloth and Hair is back + Question.
Mazak ( ) posted Wed, 21 September 2005 at 6:24 AM · edited Sat, 25 January 2025 at 1:54 PM
Poser 6 SR1 Dynamic cloth and Hair is back with the latest patch. I noticed a new import setting 'use quaternion interpolation'; what did this mean? Mazak
Google+ Bodo Nittel
Mazak ( ) posted Wed, 21 September 2005 at 6:25 AM
Here an example render time 27 seconds on my Athlon 3500. Mazak
Google+ Bodo Nittel
wabe ( ) posted Wed, 21 September 2005 at 6:34 AM
I probably was the reason for this. I did a Poser animation a while ago and imported that into Infinite. Strangely enough, there was a movement in the animation that was not there in Poser. I reported, sent all the files to e-on and this is the result. E-on found out that some animation splines are differently interpretated from the programs. Until this is clarified with e-Frontier (my guess) they built in this question to be able to switch when something does look strange. to give you the option to try out another method. Unfortunately this does not solve my problem yet.
Mazak ( ) posted Wed, 21 September 2005 at 6:50 AM
Thank you :) I will finish my walk animation; maybe I see a difference. Mazak
Google+ Bodo Nittel
jc ( ) posted Wed, 21 September 2005 at 12:48 PM
While on this Vue 5i dialog: What is the meaning of the bump conversion ratio and what setting might be best? Thanks...
Dale B ( ) posted Wed, 21 September 2005 at 6:42 PM
The bump conversion setting was added due to the fact that so many of the bumpmaps that Poser uses vary in depth detail by a significant degree; so much so that it was futile to try and hard code a conversion factor. And you will pretty much have to experiement here. Some bumps are fine at zero. Some require high numbers, some fractional numbers.
jc ( ) posted Wed, 21 September 2005 at 6:47 PM
Ah, thanks Dale. I'm just learning Poser, via Poser 6, so very valuable info.
svdl ( ) posted Sun, 25 September 2005 at 5:55 PM
Dynamic hair import still has a glitch: you can only import a complete animation, a single frame import causes Vue to crash to the OS. And has anyone found a way to get rid of the grainy look on rendered dynamic hair? It's quite annoying, especially on lighter colored hair.
My gallery   My freestuff
wabe ( ) posted Mon, 26 September 2005 at 12:59 AM
There is a tutorial out somewhere to get rid of the grainy look of dynamic hair. But where? I forgot where to be honest. I will do a search again and post it. But in fact, it has to do with deleting the strange function that come with the import and then play with the anti-aliasing settings.
