Tue, Jan 14, 5:49 PM CST
Subject: Ecosystem question
mstnicholas1965 ( ) posted Wed, 21 September 2005 at 1:28 PM ยท edited Tue, 26 November 2024 at 11:51 AM
Does anyone know if this is possible? Let's say that you have created a number of items ( in case playing cards) and when you created and saved them they were set up vertically ( stanging up on edge) but you want them to be laying down horizontally, face up (as on a table) when used in the ecosystem. Is there any way to do this on the fly or do I need to re-save the object in the correct orientation? Appreciate any insight. Thanks. MDT
DVcreator ( ) posted Wed, 21 September 2005 at 3:08 PM
What Version of VUE , In VUE4 I would rotate on the the objects axis and then drop object to surface.
mstnicholas1965 ( ) posted Wed, 21 September 2005 at 3:44 PM
It's Vue 5 Infinite. I wouldn't be an issue to rotate the object axis, but there are 52 of them and hence would be time consuming. Any way to do it globally?
lingrif ( ) posted Wed, 21 September 2005 at 6:22 PM
I'm not a real eco guru, but you could experiment with the eco system setting on the Scaling and Orientation tab - Direction from surface - and set that to perpendicular. That should work.
www.lingriffin.com
