Sat, Nov 9, 10:45 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 8:30 pm)
Subject: Poser 6 SAVE TO LIBRARY dialogue hidden
CuriousGeorge ( ) posted Thu, 22 September 2005 at 4:34 PM · edited Sat, 09 November 2024 at 10:15 PM
OH this annoys me, I took a lot of time to set up a bunch of keyframes. Then I select SAVE TO LIBRARY. The dialogue box appears over the view window,...
...and I accidentally click the view window. Now the SAVE TO LIBRARY dialogue box is BEHIND the view window and there's no way I can bring it back,...or is there?
I appreciate any help.
Thanks
diolma ( ) posted Thu, 22 September 2005 at 5:37 PM
Haven't actually come across this situation, but come across similar ones (in Poser)... Try minimising everything you can and look on the desktop for the hidden dialogue and/or scan the task bar for a relevant dialogue. Sometimes things show up.. Assuming you're using a version of Windoze, that is. If your on a Mac, then I've no idea... Cheers, Diolma
Little_Dragon ( ) posted Thu, 22 September 2005 at 6:54 PM
Can't you simply move the view window?
kenyarb ( ) posted Thu, 22 September 2005 at 9:52 PM
Assuming you have Windows, try these magic keys Alt-tab Switch between the open items Alt-esc Cycle through items in the order that they had been opened Alt-F4 Try, try again Windows Logo-M Minimize all windows. Sometimes this will expose hidden dialog boxes. I found Poser doesn't like this, and requires a "Ctrl-Alt-Del-Esc" to force a refresh. Or there's the three finger salute, Ctrl-Alt-Del, and use the task manager to switch windows
TrekkieGrrrl ( ) posted Fri, 23 September 2005 at 8:05 AM
CTRL-tab cycles between windows open in the same application.
