Sat, Jan 11, 12:28 AM CST
Subject: UV Mapping
mdbruffy ( ) posted Fri, 23 September 2005 at 5:49 PM · edited Sat, 11 January 2025 at 12:22 AM
Looking for a good, inexpensive program that will give a clean UV map. UVMapper shows everything- including the inside of a constructed object. I need something that will just map the surface.
geep ( ) posted Fri, 23 September 2005 at 6:42 PM
Have U tried separating it by "groups" or "material"? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
mdbruffy ( ) posted Fri, 23 September 2005 at 6:56 PM
I have. But it was built out of primatives and when I try to select just an area on the surface, the grouping tool selects everything else as well. The object is the Alliance Crusier I posted a WIP on. this is the adress; http://www.renderosity.com/viewed.ez?galleryid=1050785&Start=1&Artist=mdbruffy&ByArtist=Yes Right now, I'm trying to clean up the map that UVMapper made and it's a very long and tedious process because there are six views that have to be cleaned up.
alexic ( ) posted Fri, 23 September 2005 at 7:48 PM
Try 'materializing' it in Wings3d and then exporting the parts you want to map, not perfect but better than trying to clean up internal maps.
dan whiteside ( ) posted Fri, 23 September 2005 at 8:56 PM
Sounds like what you're looking for is an Unwrap or Shrink Wrap UV function and to my limited knowledge of 3D apps that only comes with expensive apps like Modo or Maya.
geep ( ) posted Fri, 23 September 2005 at 9:01 PM
Attached Link: http://www.unwrap3d.com/
You might try this one. It has a **free demo** and might be what you're looking for. If you like it ........... it costs ~$50. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
dan whiteside ( ) posted Fri, 23 September 2005 at 9:10 PM
Wish I'd looked at this thread a little later ;-) Good one Doc!
mdbruffy ( ) posted Fri, 23 September 2005 at 9:16 PM
Just tried it. The demo doesn't allow you to save the map so how does anyone know if they want it or not?
geep ( ) posted Fri, 23 September 2005 at 9:22 PM
Does it let you "unwrap" things?
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 23 September 2005 at 9:26 PM · edited Fri, 23 September 2005 at 9:33 PM
Hey md,
Tell you what ...
If you want to send me your object ...
I could buy the s/w and unwrap the object and see if it works.
Yes? ..... This offer is good for the next 15 minutes.
cheers,
dr geep
Message edited on: 09/23/2005 21:33
cheers,
dr geep ... :o]
edited 10/5/2019
Stegy ( ) posted Fri, 23 September 2005 at 9:49 PM
Attached Link: http://www.righthemisphere.com/products/duv/
If you've got deep pockets, you might to look at DeepUV too. They have a demo that I recently played with. You can do saves withit, but I believe has some functions disabled and expires in 30? days.
mdbruffy ( ) posted Fri, 23 September 2005 at 10:04 PM
It does unwrap- shatters the model into pieces instead of views. It comes out looking like a model kit with the pieces attached to a frame- remeber those? I would have posted a screenshot for you to see but the demo doesn't allow that either. Geep, if you really want to put out the money for something you can't really test before hand, let me know when you're ready.
UVDan ( ) posted Sat, 24 September 2005 at 1:40 AM
Forum Moderator
Looks pretty straight forward to me. UV Mapper Pro will let you select by vertex, facet, edge, group, material, geometry, uv set, or texture. Surely one of these can select the nonsurface portions and delete them. If you feel like letting me have a look at it, shoot me an IM.
destro75 ( ) posted Sat, 24 September 2005 at 6:42 AM
So did you buy it Doc? It looks like a great product. If you did, any reviews?
geep ( ) posted Sat, 24 September 2005 at 7:36 AM
" ... I would have posted a screenshot for you to see but the demo doesn't allow that either. ..."
@ mdbruffy,
Hmmm ... Well, I don't think I want a program that disables my PRINT SCREEN button. ????? Does it really do that?
Perhaps you could give UVDan a shot at it re: post #13.
cheers,(?)
dr geep
P.S. @ destro75
Actually, if I were going to do a review, I should really do one for UVMapper Pro first ... since I have been using it for years. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
mdbruffy ( ) posted Sat, 24 September 2005 at 7:44 AM
It did in my case. it wouldn't export a map and when I tried to save the screenshot and went to Photoshop to get it, the clipboard option was greyed out. There was nothing to get. I don't know if the full program does that- probabably not. But like I said before, If you can't see the final results of the program ...it'd be like buying something blind- you don't know exactly what it will do. I've sent UVDan an e-mail. See if he can help.
UVDan ( ) posted Sat, 24 September 2005 at 1:33 PM
Forum Moderator
I am looking forward to your obj. I have much confidence that UV Mapper Pro will do the job.
geep ( ) posted Sat, 24 September 2005 at 1:43 PM
Hey UV, Post a couple o' screen pics if/when you get a chance, ok? Thanks. I'm just curious. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
mdbruffy ( ) posted Sat, 24 September 2005 at 1:56 PM
The e-mail with the obj has been sent. now we can only wait and see. I honestly hope this works. But I have to say after seeing how the classic verison does, I have my doubts. I would love to be proven wrong.
geep ( ) posted Sat, 24 September 2005 at 2:19 PM
tHE pRO VERSION IS 1,000,000 times MORE POWERFUL WITH A REALTIME 3d oPEN gl DISPLAY THE YOU CAN TWIST, ROTATE, SCALE, ETC. Oops, sorry (dang caps lock thingy strikes again) ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
mdbruffy ( ) posted Sat, 24 September 2005 at 2:23 PM
I know the feeling. It happens to me sometimes too. Dan has the file now. so it shouldn't be much longer till we know one way or the other.
UVDan ( ) posted Sat, 24 September 2005 at 2:34 PM
Forum Moderator
I will have a look at it and post some screenshots later.
geep ( ) posted Sat, 24 September 2005 at 2:42 PM
Thanks UV. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
UVDan ( ) posted Sat, 24 September 2005 at 2:55 PM
Forum Moderator
You can tell this is a Poser model, because some of the parts are so small, they are invisible in the left hand pane. I also got an "error opening material library" message. Not to worry though. I will deal with it.
geep ( ) posted Sat, 24 September 2005 at 3:08 PM
WOW ! You're fast! ........ me? ...... I'm only half-fast. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
UVDan ( ) posted Sat, 24 September 2005 at 3:15 PM
Forum Moderator
UVDan ( ) posted Sat, 24 September 2005 at 3:18 PM
Forum Moderator
This will be the last screenie for a while as I need to wring this model out. I will report back with the progress later.
UVDan ( ) posted Sat, 24 September 2005 at 3:20 PM
Forum Moderator
You're welcome geep.
mdbruffy ( ) posted Sat, 24 September 2005 at 3:22 PM
If there's anything else I can do to tyr to help, let me know.
geep ( ) posted Sat, 24 September 2005 at 3:23 PM
cheers,
dr geep ... :o]
edited 10/5/2019
UVDan ( ) posted Sat, 24 September 2005 at 3:34 PM · edited Sat, 24 September 2005 at 3:39 PM
Forum Moderator
Just to show how straight forward this process is so far. Please note that I have activated the color texture checker feature by going to going to Texture/checker/color. I love this feature because it lets you get distortion free maps by making sure the squares are square in both views. If the squares are rectangles in the prespective view, then you need to resize the selection in that direction. No sweat mdbruffy, I will be in touch.
Message edited on: 09/24/2005 15:39
mdbruffy ( ) posted Sat, 24 September 2005 at 3:40 PM
So this doesn't do planer and box and so on, like the classic verison?
mdbruffy ( ) posted Sat, 24 September 2005 at 3:42 PM
Okay, I'm probably jumping the gun. sorry.This is only the second time that someone else has worked with my designs so I'm a little on edge.
geep ( ) posted Sat, 24 September 2005 at 3:48 PM
Easy does it md ...I know how you feel. I know UVDan will do you proud. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
mdbruffy ( ) posted Sat, 24 September 2005 at 3:50 PM
Thanks, Geep.
geep ( ) posted Sat, 24 September 2005 at 3:52 PM
cheers,
dr geep ... :o]
edited 10/5/2019
UVDan ( ) posted Sat, 24 September 2005 at 3:54 PM
Forum Moderator
It's ok mdbruffy. Do not sweat. UV Mapper Pro does Planar, Box, Cylinder (with and without caps), Spherical, and Polar mapping as represented by the icons across the top right.
geep ( ) posted Sat, 24 September 2005 at 4:00 PM
Din't I tole ya. ............................................ ;=] <<<<<<<<<<<<< (fairly large grins)
cheers,
dr geep ... :o]
edited 10/5/2019
UVDan ( ) posted Sat, 24 September 2005 at 4:00 PM
Forum Moderator
Attached Link: UV Mapping Forum Tutorials
mdbruffy in case you have never been to the UV Mapping forum here I am linking the tutorial section. There is not much there at the moment. Most of it relates to aircraft because that is my passion, but I will be expanding on it soon.
mdbruffy ( ) posted Sat, 24 September 2005 at 4:01 PM
(with a lrge grin) okay...thanks.
mdbruffy ( ) posted Sat, 24 September 2005 at 4:02 PM
Let me know when it's ready.
UVDan ( ) posted Sat, 24 September 2005 at 4:08 PM
Forum Moderator
I will be in touch, don't worry.
diolma ( ) posted Sat, 24 September 2005 at 5:30 PM · edited Sat, 24 September 2005 at 5:32 PM
@ mdbruffy,
Errm... Surely you can use PaintShopPro (or almost certainly Photoshop (which I can't afford)) to capture screen shots??? That's how I always do them (My "Print Screen"/"SysRq" key is hidden under a layer of dust - I've never used it. Done lots of screen-caps tho.. using PSP v4!
Cheers
Diolma
Message edited on: 09/24/2005 17:32
UVDan ( ) posted Sat, 24 September 2005 at 5:40 PM
Forum Moderator
Hi diolma! When I cannot use the printscreen button I use the Corel Capture utility that comes with Corel Photopaint. Until you posted I had forgotten about it. It is very rare that I cannot use the printscreen button, and it is usually more convenient to do so.
mdbruffy ( ) posted Sat, 24 September 2005 at 5:47 PM
I only have Photoshop Elements- Photoshop's little brother. This demo was the first time I couldn't do a screen capture- that fact doesn't do alot to encourage me. Kind of makes me wonder what they're hidding. If the program's really that great and they really want people to see how good it is, why don't they have a full verison with a 14 day or 30 day life-span?
geep ( ) posted Sat, 24 September 2005 at 5:48 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sat, 24 September 2005 at 5:50 PM
................... NaySay says it's "camouflage." ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
UVDan ( ) posted Sat, 24 September 2005 at 5:51 PM
Forum Moderator
I will bet that NaySayGuy got beat up ALOT when he was going to school. 8^)
mdbruffy ( ) posted Sat, 24 September 2005 at 5:51 PM
That's good. Real good.....
geep ( ) posted Sat, 24 September 2005 at 5:55 PM · edited Sat, 24 September 2005 at 5:59 PM
School? ....................... What's that?
(Editor's note - NSG flunked "sandbox" and never made it out of kindergarden)
Edited to remove all:
None, Nudity, Violence, Both, TOS violations, cuss words, dirty jokes, and all of Doc's TOP SECRET information.
Message edited on: 09/24/2005 17:59
cheers,
dr geep ... :o]
edited 10/5/2019
UVDan ( ) posted Sat, 24 September 2005 at 10:58 PM
Forum Moderator
Everything with numbers and squares is currently mapped.
