Tue, Jan 28, 4:25 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: Glamerous Jesse updates?
Marque ( ) posted Mon, 26 September 2005 at 11:08 AM ยท edited Mon, 27 January 2025 at 5:17 AM
Just started working with her and noticed this in the item as soon as I loaded her up, have there been any updates for her? If not I feel like I've wasted my money. The elbow and wrist are terrible on both jessie and glennis. Sorry for the poor image probably should have rendered it first. Marque
Jim Burton ( ) posted Mon, 26 September 2005 at 11:20 AM
Terrible how? I can't see anything from your picture, other than the seam in the stock texture (which only shows up in preview).
Marque ( ) posted Mon, 26 September 2005 at 1:57 PM
Her wrist looks like it has a sleeve and I will post another render of her elbow which also overlaps. Marque
Marque ( ) posted Mon, 26 September 2005 at 2:03 PM
Ahhh so that is a texture seam? Had me nervous there for a minute. Thanks for getting right back to me, appreciate it. Didn't realize those were seams, they looked like she had some weird morph going on. Marque
Jim Burton ( ) posted Mon, 26 September 2005 at 5:51 PM
Yeak, for some reason Glamorous Jessi (and Stock Jessi) do so a lot of visable seams in preview mode. I don't know why, must have something to do with how the mapping is laid out. They do go away when you render, though. Incidently, I am working on an SR-1 upgrade for GJ, I found a couple little things, it will be free, of course.
Marque ( ) posted Mon, 26 September 2005 at 6:58 PM
Thanks so much. Just now getting around to using them. Marque
layingback ( ) posted Tue, 27 September 2005 at 11:27 AM
I believe the appearance of seams is because the textures stop at the edge of the figure's template. (I don't have a Jessi seam template to compare, but it looks as if they do.) What happens I think, is that in preview mode the texture is scaled down drastically, and probably crudely as this is "only" preview. E.g. a sample of pixels is presumably taken and averaged down to 1 pixel. (Which would explain why larger texture maps seem more blurry in preview than smaller ones.) And at the very edges of the template non-image pixels are incorrectly sucked into the averaging process and thus the image, leading to a coloration error - typically a lighter banding. This would also explain why "hi-res" textures seem to exhibit worse seams, more scaling down would - if the theory holds - mean more off-image pixels sucked into the preview at the edges. This theory could be tested by changing the color of the unused portion of the map to black to see if the seams go dark. It's often said that good textures should not wash across the entire map, but I think there is something to say for careful overlap of the template edges. For best results they should be part of the image from the other side of the seam.
