Fri, Jan 24, 8:35 AM CST
Subject: Camera direction issues in animation
ZeeDoktor ( ) posted Mon, 03 October 2005 at 8:11 AM ยท edited Fri, 24 January 2025 at 3:12 AM
Hi all, I'm completely new to Vue5 infinite and am trying to animate a flying around a mountain clip, where the camera faces halfway forward in the beginning and then focuses onto the peak of the mountain and stays there until we have flown around it. My issue seems to be that I can't get the direction the camera is facing to transition smoothly from the forward motion to the lefthand sweep motion. So we're flying forward, then suddenly the camera jerks a bit and faces the center of the mountain while we keep rotating. I need to de-jerk that transition. Does anyone here have any idea how that could be done? Is it possible to automatically "glue" the direction/focus of the camera to another object that can be moved on a spline? Thanks - Balt
wabe ( ) posted Mon, 03 October 2005 at 8:59 AM
One option would be to link the camera to a cube that is not rendered. Then you can animate this cube and do the complex movement you want to do. For example let it move up until it reached the top of the mountain and then let it rotate only. The camera is following that then without problem.
