Forum Moderators: RedPhantom
sitting comfortably
Outdated gallery over at DeviantArt
Fics at FanFiction.net and Archive of Our Own (AO3)
Doc, is this do-able in ProPack too ?
In a word ... ABSOLUTELY !!! Hi vilian, Thank you for asking ... the answer is ... YES! As a matter of fact ... I'll do the rest of the tut using only Poser 4. You can use ... - Poser 4 - Poser ProPack - Poser Artist (same as Poser 4) - Poser 5 - Poser 6 - Poser 7 ... for this tutorial. ;=] cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
@ Diolma, Good point! Yes, you are absolutely correct that scrolling should not be necessary ... +++ unless +++ ... the DoggieBot folder is put in a sub-folder and there are enough sub-folders to make scrolling necessary. And, yes, you are, also, correct that NSG did that page. ;=] (Thanks for giving me a way "out" of that one.) cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Tune in and watch NaySayGuy get really pi$$ed <=== (can I say that?) off of at the Doc.
cheers,
dr geep
Edited to remove all: None, Nudity, Violence, Both, dirty jokes, cuss words, NaySay's dirty laundry, TOS violations, and all TOP SECRET information. Message edited on: 10/08/2005 17:28
cheers,
dr geep ... :o]
edited 10/5/2019
Hi Geep! You get a flat bottom to the foot here by pulling mesh, but my question is, can one flatten a curved mesh within poser? I have tried all sorts of graph setting to try to flatten the side of a ball prop and to try to get the look of a face or breasts pressed against a flat pane of glass. Nothing remotely like success... is this a posible feet ;)
re: " ... can one flatten a curved mesh within poser?"
Hi momo,
Yes, but it's tricky.
Take a look at Page 22 ... (which has not been posted ... yet) ....... and see if it gives you some ideas.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
I'm using Poser 5
Message edited on: 10/17/2005 12:03
say." - Ghandi
Hi Acadia,
Sorry you're having trouble.
Try this:
Place the "Zone" so that it only has the top half of the ball inside of it.
Now move the Magnet up and down - both above and below the ball.
Yes?
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Thank you! That worked. I moved the Mag1 up as far as I could, which is a bit less than 1/2 the height of the ball, and now I can change shape using the Y Trans. runs off merrily to try the next page
say." - Ghandi
say." - Ghandi
Ok ... Change the Mag's yScale back to 100%.
Now, move the "Zone" to the front (+zTran) just a little bit and watch the ball change shape.
BTW - Changing all 3 (x, y, and zScale) values is the same as changing the Scale parameter ... it just makes the object bigger but does not deform anything.
Make small changes and only change one thing at a time and I'll be back in about an hour.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
I get the tutorial up to the point where I add the magnet. But after that, I'm totally lost. I went back to Page 5 and did it all again from square one. Again, the ball does not change shape based on the steps listed in that picture. If I move the Mag1 up on the Y Trans, the ball does change shape. But the shape isn't anything like what you have posted. If I just add the magnet and don't move the Mag1 up on the Y Trans, the ball doesn't change shape at all.
say." - Ghandi
hehe, thanks Dr. Geep! I am up to page 10 now but am stuck. How do you get a side camera view? I don't see any camera with that name in the drop down menu.
say." - Ghandi
Thank you :) Can you tell I'm in territory that I've never been before? LOL I hope I don't have to bother you too many times getting through the rest.
say." - Ghandi
Hi Folks, Here we go ...................................... again. ;=] DoggieBot ??? ... You can do it .............. Doc can help. ;=] Hmmm ..... where have I heard that before? cheers, dr geep ;=]Remember ... "With Poser, all things are possible, and poseable!"
cheers,
dr geep ... :o]
edited 10/5/2019
