Sun, Jan 12, 3:18 AM CST
Subject: Poser & Bryce Animation ?
BarukKaah ( ) posted Sat, 03 March 2001 at 6:58 PM · edited Sat, 10 August 2024 at 5:19 AM
I've been searching through some tutorials now and have a question. I've made an animation in Bryce4 and another in Poser4 Is it possible to put the two animations together(Having the poser character moving in a moving bryce environnement)?
KenS ( ) posted Sun, 04 March 2001 at 12:55 AM
yes, but not without lots of work, your best bet is to render the animated scene in Bryce, then import as a background avi in poser to do your character animation on top
BarukKaah ( ) posted Sun, 04 March 2001 at 10:17 AM
Okay, thanks a lot for answering. But you said it was possible to get the animated character in Bryce, do you know a tutorial or something that could help me doing that? Also, if I export my Poser character as a multiframe stuff, can Bryce take each obj to place them on the correct frame (thus rebuilding the animation) ? Thanks again...
KenS ( ) posted Sun, 04 March 2001 at 1:12 PM
it will all have to be done by hand. www.3dartist.com did have a tutorial on their site.
3ddave44 ( ) posted Mon, 05 March 2001 at 7:35 PM
and when they say by hand, they mean - exporting each instance of the figure from poser as an .obj and then importing into Bryce, positioning where necessary, rendering, and so on for each movement or frame of the poser motion! I kid you not. another way which works if you don't require camera movement is too render the background in bryce and import that as a background in poser and then animate the figure as normal. render as many different angles of the background in bryce that you need to add variety and you can often get by with this method. dave www.citizendave.com
