Fri, Jan 10, 9:51 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: How do you get hair to conform to a different character?
renderq ( ) posted Fri, 07 October 2005 at 5:15 PM · edited Fri, 10 January 2025 at 9:42 PM
Is it possible to get hair designed for one character to conform, if not parent to a another character? Example: Hair designed for Jessi to work with Stephanie Petite. Many thanks in Advance rq
la_morocha ( ) posted Fri, 07 October 2005 at 6:02 PM
I use the freebie utilities from www.netherworks-studios.com . They are magnet sets and center-set poses that let you generate a hair fitting morph in the new hair that is generated. - Yolanda
fls13 ( ) posted Fri, 07 October 2005 at 7:05 PM
Hope it works. I've been meaning to ask this question myself for awhile.
MaryK ( ) posted Fri, 07 October 2005 at 7:30 PM
yes, netherwork's magnets do work well when your translating hair from one figure to another.
thefixer ( ) posted Sat, 08 October 2005 at 3:35 AM
If you don't want to get that magnet set it is possible to fit hair to others by using the XYZ parameter dials for placement and the XYZ scaling dials to fit. Once you have the fit right then just parent it to the "head" of the character like you would parent a prop. Works great for most but not for all and it's quicker than it sounds! thefixer, poser coord.
Injustice will be avenged.
Cofiwch Dryweryn.
fls13 ( ) posted Sat, 08 October 2005 at 11:32 AM
Yeah, but what about figure hair as compared with prop hair?
thefixer ( ) posted Sat, 08 October 2005 at 11:43 AM
You don't "have" to conform a figure, you can still parent it instead so it's not an issue! thefixer, poser coord.
Cofiwch Dryweryn.
diolma ( ) posted Sat, 08 October 2005 at 4:01 PM · edited Sat, 08 October 2005 at 4:01 PM
Wardrobe Wizard makes a reasonable stab at doing this (probably not good enough for close-ups, but...)
Cheers
Diolma
Message edited on: 10/08/2005 16:01
renderq ( ) posted Sat, 08 October 2005 at 5:49 PM
Thanks everyone. I'll give them all a try. rq
