Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 11:30 pm)
Is that a trick question? Poser 6 scenes should import into Poser 6 flawlessly. If you mean into Vue (as implied by your header) I believe that you can import .PZ3 into Vue depending on your version of Vue. Perhaps I have missed something in your question and if I have I'll shut the hell up and let someone else step in. :)
I have'nt had any problems leaving Poser running while loading a pz3 into Vue, in fact I usually do that so that if the figure needs adjustment I can do it straight away, resave and reload into Vue. Having two monitors helps because you can see both scenes at the same time. Regarding pointing Vue to the Poser directory,it never asks me. I think thats because everything on my runtimes is saved using full paths. The only message I get from Vue when I load a Poser file is that I do not have sufficient memory. but I just ignore that and it works anyway.
I was just wondering if there is anyway to export Poser 6 scenes directly into Poser 6 or am I to do it the old fashioned Bryce way by exporting as an OBJ ? thanks in advance
