Sun, Dec 1, 5:58 PM CST
Subject: Need help with M3 shorts
sturkwurk ( ) posted Sun, 09 October 2005 at 6:27 PM ยท edited Sun, 01 December 2024 at 5:45 PM
I have these shorts in my M3 clothing library... I don't even remember where I got them... I think they may have been a daz freebie at some point? Here's the problem, I finally need to use them, but when I go to load them from my library, they fail to show up... I don't get any errors, they just don't show up. The geometry reference seems fine, there's actual geometry where there should be. (they are in a Daz folder) Does this ring any bells?
I came, I rendered, I'm still broke.
SamTherapy ( ) posted Sun, 09 October 2005 at 6:45 PM
Yep, it does. I can't remember the solution to the problem, though. I think they were corrected and offered again. They were a DAZ freebie, I can remember that much.
sturkwurk ( ) posted Sun, 09 October 2005 at 6:55 PM
Thanks, I'll try over at the Daz fourm and see if that can rattle loose an answer. Doug
Lucca ( ) posted Sun, 09 October 2005 at 9:33 PM
Have you tried deleting the RSR file? When Poser says that it cannot find the geometry, the problem is often a corrupt rsr file.
sturkwurk ( ) posted Sun, 09 October 2005 at 9:43 PM
Great Idea, I forgot about trying that one. Rats, didnt work I did find that the cr2's reference body2 instead of 1, but even after changing all of them, it still didnt work. Doug
MarianneR ( ) posted Mon, 10 October 2005 at 9:29 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1453818
Here's how to fix it with UV-Mapper.
profotograf ( ) posted Mon, 10 October 2005 at 4:20 PM
The textures look like ones done by RichardT, I'd check with him on where it was from. Greetings, Antonio
Greetings from Germany
ProFotograf
My PoserAddicts
randym77 ( ) posted Mon, 10 October 2005 at 5:14 PM
Those are the DAZ shorts, which were a temporary freebie. There was a bug in the original release. They issued a fixed version later, but a lot of people didn't know about it. You can fix it yourself in UVMapper, but it's kind of a pain.
