A workaround for this is to switch on genitalia in the menu, that should fix the problem. It probably does happen in poser 5, it happens in propack and poser 4 too, it is caused by the geometry switching part of certain male figures, it doesnt happen with michael 3 because m3 doesn
t use geometry switching he has a completely seperate appendage.
Here's the part of the cr2 you are looking for. It's under the actor hip actor hip:7 { name GetStringRes(1024,6) on bend 1 dynamicsLock 1 hidden 0 addToMenu 1 castsShadow 1 includeInDepthCue 1 parent BODY:7 alternateGeom hip_1 { name Genitals Off objFile 20 :Runtime:Geometries:P5NudeMan:blHipNoGen.obj } channels If you remove these alternateGeom lines and resave the cr2 it won't happen.
Never had this problem in P5, but in P6 when I create a figure in the setup room and then either save it and reload or apply a library pose file, the new hip geometry is replaced by nude figure geometry. How can I keep that from happening?!?!
