Wed, Oct 2, 11:31 PM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 02 9:25 am)
Subject: Big pauses in matroom with MIKI...???
richardson ( ) posted Mon, 17 October 2005 at 6:09 PM · edited Wed, 02 October 2024 at 9:33 PM
Anyone else experience the long delays when working on nodes with MIKI? Is there a filesearch going on that I'm not aware of. I've installed her 3 times now and cannot trace the cause. Reason I ask is I get a lot of exporting and UVmapper problems with her too.
face_off ( ) posted Mon, 17 October 2005 at 11:19 PM · edited Mon, 17 October 2005 at 11:21 PM
Set WRITE_FILE_SEARCH_LOG to "1" in Runtime/prefs/Poser.ini. That might tell you what search paths it's using (it works for pz2 files - not sure about the mat room). From memory, it saves a file into the Poser 6 directory which you can examine in wordpad.
Message edited on: 10/17/2005 23:21
Creator of PoserPhysics
Creator of OctaneRender for Poser
Blog
Facebook
richardson ( ) posted Tue, 18 October 2005 at 12:10 AM
Thanks buddy. I can no longer take a 12 second delay on every matroom function. Especially when it's in the 100's, now.
Jeff01 ( ) posted Tue, 18 October 2005 at 7:51 AM
I experience long pauses with the Poser 6 Mat Room in general. If I double click on a material from the library palette, sometimes the nodes appear right away, sometimes they appear after a long pause, and sometimes they don't appear until I move the mouse. I know that sounds weird, but I always move the mouse now if I experience a delay in the Mat Room, and the nodes appear.
Jeff
semidieu ( ) posted Wed, 19 October 2005 at 5:42 AM
Don't forget that if you have a lot of lights, it will also increase a lot the response time... Also, if you don't need the preview, you can disable it (click the eye on the top of a node). It will be very fast... but no preview... Really usefull to copy/paste node between materials.
