Mon, Feb 17, 7:30 PM CST
Subject: Q : Poser Import : dynamic hair and cloth animation.
Holli ( ) posted Thu, 20 October 2005 at 8:15 AM · edited Tue, 04 February 2025 at 4:46 AM
Hello, I never tried it yet so I decided to ask first before I spend hours finding out myself. As far as I know the wind in Vue5Inf. is able to animate hair and dyn.clothing of imported Poser scenes. How do I set this up ? I have a Poser scene ready with dynamic cloth already calculated. What is the next step ?
Cheers ( ) posted Thu, 20 October 2005 at 9:27 AM
Holli, Vue will only import the Poser scene, so any wind dynamics and or animation has to be set up in Poser also, then just import the PZ3 file into Vue and it will ask you if you want to import just one frame, or the whole animation. Using the breeze/wind feature in Vue for example, will not have any effect on Poser dynamic cloth or hair once in Vue...i.e. you will not see Vue wind/breeze blowing against an imported Poser dynamic hair or cloth model. Hope that helps. Cheers
Twitter: Follow @the3dscene
Holli ( ) posted Thu, 20 October 2005 at 10:06 AM
Thanks a lot, that helped me a lot. I hoped it would be different but maybe Vue 6 will do that one day.
Cheers ( ) posted Thu, 20 October 2005 at 10:10 AM
My pleasure :) Well, I think a full blown dynamics system in Vue is very likely at some point...it will just depend on what type of mesh it can be used with if and when it does happen. Cheers
Burnart ( ) posted Fri, 21 October 2005 at 2:36 AM
Can't speak for the imported hair and cloth in the latest versions of Vue and Poser but it looks good in Vue4 from Poser5 - although the hair ends up looking much coarser than it does in Poser.
estherau ( ) posted Fri, 21 October 2005 at 7:04 PM
YOu fix the courseness of transmapped hair in the highlights section. Make hair lighter and decrease the reflectivity I think from memory, this fixes it really really well. Love esther well poerhaps it will woork for dynamic hair to, but I've not tried dynamic hair yet.
MY ONLINE COMIC IS NOW LIVE
Dale B ( ) posted Sat, 22 October 2005 at 6:21 AM
Holli; While it is true the Vue 'wind' will not affect a Poser import, it is quite possible to create the effect in Poser and make it -appear- to. The problem is that they work differently. Poser windforce is closer to being water than air;you have to tweak both the windforce parameters and the hair parameters to get the kind of turbulence that you want (This applies to both cloth and hair, btw). The Vue side of the problem is that the wind is a runtime effect; it simply isn't there until you actually render the scene. What I've found works best for me is to do a preview render of the Vue scene, so you can see exactly which frame a gust begins, and when it eases, and you take that frame info into Poser and keyframe the the Vue wind cycle into the Poser windforce generator. It's not exact, but its the best that can be done at the moment.
