Thu, Feb 6, 9:49 PM CST
Subject: Read Me
scoleman123 ( ) posted Tue, 18 October 2005 at 2:39 PM · edited Mon, 13 January 2025 at 5:12 PM
  1. for starters, is it possible to have a bryce animation play faster. Specs: 872 megs, 16 seconds, 30 Fps, lowest render setting. Curently using WMP at school. at home it is no problem. 2. http://www.renderosity.com/tut.ez?Form.ViewPages=990 my first tut. 3. Drac, i will be sending you some free stuff for WOB soon.
 facebook.com/scoleman123
draculaz ( ) posted Tue, 18 October 2005 at 3:43 PM
yay!
AgentSmith ( ) posted Thu, 20 October 2005 at 4:59 AM
What little animations I have done, I export out of Bryce as images, and then encode later. When encoding, can't you just set the fps higher than 30? AS
scoleman123 ( ) posted Thu, 20 October 2005 at 2:07 PM
Well, the problem is that it takes about a day to cach in WMP (at school). but even then it play slow. the 16sec movie turns to a 30 minute frame by frame drag out.
AgentSmith ( ) posted Thu, 20 October 2005 at 3:23 PM
What's your frame size? And, what are you encoding it as? AS
TobinLam ( ) posted Thu, 20 October 2005 at 6:11 PM
Frame size is a major factor. I have a quicktime movie with a pretty large frame size that freezes a lot but after several runs is finally smooth.
AgentSmith ( ) posted Thu, 20 October 2005 at 8:55 PM
At the largest (so far), I render out to fit DVD specs; 720x480 (which is USA NTSC). Sometimes, I render to fit a small PC screen resolution(800x600), but mostly I take my little animations, and burn them to DVD to play on my television. I'm sure at some point I'll render out larger, if only to take advantage of some HD rig I could play my animations on, lol. ;o) AS
scoleman123 ( ) posted Fri, 21 October 2005 at 2:35 PM
900 x 675 and uncompressed (.AVI)
AgentSmith ( ) posted Sat, 22 October 2005 at 12:13 AM
Hmmmm, what fits that frame size? Perhaps if you did compress it, it would play more easily? (I'm not actually sure of that suggestion, never actually tried to see whether or not an uncompressed avi pulls more cpu power than a compressed one) AS
