Tue, Nov 26, 6:48 PM CST
Subject: Vue5 Poser import jpg "unsupported file type" error
jamesd1 ( ) posted Thu, 20 October 2005 at 6:02 PM ยท edited Tue, 26 November 2024 at 6:37 PM
I have a series of jpg texture files that Poser 6 is working with OK. On import, most all of these come in fine, then it comes to two hair textures which it fails to recognize with: Unable to read... invalid or unsupported file format jpg I tried loading the jpg into PaintShop Pro, resaving it and also reducing it's size. This error presists and I've no clue why it does not like these two jpg files but brings in all others OK
Elminster_ZK ( ) posted Thu, 20 October 2005 at 6:41 PM
It's not just with poser imports - with alpha plane or terrain import jpegs, I get an error with some files too. Somebody help us!
"Walk down the right back alley in Sin City, and you can find anything."
jamesd1 ( ) posted Thu, 20 October 2005 at 6:54 PM
Hi Elminster, Maybe someone here will have some info. Meanwhile, I've also send email to Vue tech support and will let you know what they say. Jim
lingrif ( ) posted Thu, 20 October 2005 at 8:57 PM
I've hit that error too. Originally I had thought it was that jpeg2000 or whatever, but photoshop opened it as a normal .jpg with no problems.
www.lingriffin.com
Djeser ( ) posted Thu, 20 October 2005 at 10:56 PM
I haven't run into that error; you might want to put in a tech support ticket and attach one or two of the files for them to look at.
Sgiathalaich
nahie ( ) posted Fri, 21 October 2005 at 12:56 AM
I think you can save .jpg files with different profiles. The most common one is "baseline" profile I think. This is NOT the compression setting, but rather some sort of profile. Photoshop has 3 options. Baseline, progressive and some other one. I think Vue (and actually a lot of applications) only supports baseline profile.
hein ( ) posted Fri, 21 October 2005 at 1:34 AM
Sounds familiar, we ran into that problem with images saved in JPG format from PsP, if the "Chroma Subsampling" was changed from the default setting, the image would only load into a few programs. Opening the file and saving with the default JPG Chroma settings solved the problem.
Chroma default in PsP = "YCbCr 1x1 1x1 1x1 (None)"
Elminster_ZK ( ) posted Fri, 21 October 2005 at 7:30 AM
Ah, I see. Thanks, guys.
bruno021 ( ) posted Fri, 21 October 2005 at 8:12 AM
Funny this is reappearing, I had this error message with an earlier built, Vue then wouldn't load my scenes that contained incorporated jpeg texture maps.
kyraia ( ) posted Thu, 27 October 2005 at 5:38 AM
I had an error like this one just today with Poser. What I finally did was to open the jpg-file in Photoshop and save it under a different name. The new file then worked perfectly.
