Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 9:03 am)
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1977525
If you want to try it yourself, you can find Geep's Setup Room tutorial here. But before you get into that, you should know that before you start, your model should be in a "neutral" pose. Any particular joint should look either unbent or half-bent and no twisting. Other than that, I can't really help you. I've never personally set up a figure. I'm still working on my first prop! :O Cute little alien! :)KDoug is wise... Yes, in order to make this figure poseable, you'll need to adjust the mesh.. Straighten the legs and the horns, make the eye face straight ahead, and if the neck is bent at all, straighten that. Then it shouldn't be all that difficult to "Poserfy" it..:-)) (either for youself or anyone who undertakes it for you..) I realise that straightening the legs would lift all 4 off the ground, but that's where the start point should be ("zero pose") Then, when it's boned etc, it can be posed in a "default" pose that anyone can start from (just like the bent legs of the Poser figures)... But without doing that, boning it might be a lot more work.. Cheers, Diolma
