Thu, Jan 9, 4:27 AM CST
Subject: Using morph manager
cole4965 ( ) posted Tue, 25 October 2005 at 8:22 PM ยท edited Wed, 08 January 2025 at 1:10 PM
I am trying to use Morph manager to add morphs from one character file (.cr2) to another. After I copy the morph it does show up as a dial but it doesn't work? Not sure what I am doing wrong. Any tips or help? Thought thsi would be an easier way to go than creating magnet etc. thanks cole4965
Tashar59 ( ) posted Tue, 25 October 2005 at 10:21 PM
They have to be from the same mesh. V3-Steph,Laura. V2-mil girls and so on. The dials will show up but as you found out, they won't work if not for same mesh.
cole4965 ( ) posted Wed, 26 October 2005 at 6:03 AM
Thank you for the response. I am trying to make a piece a clothing fit a character it was not designed for with little success. Not sure as to the best way to approach this.
cole4965 ( ) posted Wed, 26 October 2005 at 6:04 AM
Tashar59 ( ) posted Wed, 26 October 2005 at 6:48 AM
Attached Link: http://www.philc.net
OK. Tere are a couple of ways to do it. You can resize the clothes using the xyz scales and magnets. then export the cloth as a wavefront object. Then hack a clothing CR2 for the figure you want to use it on and point it to the new object. This will take some learning to get it working right. You can purchase Wardrob Wizard by PhilC. This will convert most figures clothes to most other figures. This is a very good product. I recommend this one. There is also Clothing Converter. I think it's here in the RMP or else it's at Daz, old age, I can't remember. Then ther is Tailor at Daz. This only moves morphs from a figure to a clothing item that it was made for.
AntoniaTiger ( ) posted Wed, 26 October 2005 at 7:00 AM
It's getting so that the standard response to that problem is to say "Wardrobe Wizard", which does make such work hugely easier. I have altered clothes without that, but it's tricky. Sneaky trick #1: If the body part is entirely covered by the clothing, turn it invisible.
Tashar59 ( ) posted Wed, 26 October 2005 at 1:02 PM
Right, use the sneaky trick with xyz scaling works. It's such a habit to turn things invisable, I tend to forget that it's a trick that many don't know about.
cole4965 ( ) posted Thu, 27 October 2005 at 11:14 PM
Thanks for all your help! Some great tips! I will look into all suggestions.
