Yes! Simply have an image sequence - i just tested it with xxx001.jpg, xxx002.jpg, xxx003.jpg... I loaded the first one as image map to the plane. Infinite saw that it is the first of a sequence and asked wether i want to load the whole sequnce. If you answer "yes"....
Can one map an image sequence onto an alpha plane? I'm using Lightwave to render a volcano blast using the particle system, then I plan to map it onto a plane and place it in the crater in Vue. Can this be done?
