Wed, Dec 25, 9:45 AM CST
Subject: Alpha plane
tony3d ( ) posted Fri, 28 October 2005 at 7:50 AM ยท edited Tue, 24 December 2024 at 10:57 PM
Can one map an image sequence onto an alpha plane? I'm using Lightwave to render a volcano blast using the particle system, then I plan to map it onto a plane and place it in the crater in Vue. Can this be done?
wabe ( ) posted Fri, 28 October 2005 at 8:01 AM
Yes! Simply have an image sequence - i just tested it with xxx001.jpg, xxx002.jpg, xxx003.jpg... I loaded the first one as image map to the plane. Infinite saw that it is the first of a sequence and asked wether i want to load the whole sequnce. If you answer "yes"....
tony3d ( ) posted Fri, 28 October 2005 at 8:24 AM
I did that but the problem is the first few frames are black and it does not seem to pickup the alpha.
wabe ( ) posted Fri, 28 October 2005 at 8:30 AM
Have you tried to load the alpha animation the same way? And are the first frames really colored?
tony3d ( ) posted Fri, 28 October 2005 at 9:07 AM
figured it out. If I load a 32 bit tif image sequence the alpha channel does not load, but if I render separate jpg's for the color channel and alpha channel in separate imges, I can load the alpha image sequence independant of the color. This works fine.
wabe ( ) posted Fri, 28 October 2005 at 9:10 AM
tifs with embedded alpha information are weird anyway. Not really standard. So no wonder if that does not work correctly everywhere. However, good that it works!
