Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 4:45 pm)
My python page
My ShareCG freebies
One shortcut that helps: Instead of using the selections at the top, you can usually just hover the cursor over the desired part of the scene itself; you'll see a 'medicine dropper' cursor. Click on the desired area, and the object and material will automatically appear in the selection areas. This will work if the desired material is large or nicely visible; for small or less-visible parts you'll generally need the selector pulldowns.
My python page
My ShareCG freebies
I downloaded some textures off the net to use in Poser. I loaded a flat primitive object in the pose room then I went into the material room to apply the texture but I dont know how. I know how to apply textures that shipped with Poser. But I dont know how to apply textures that arent in the poser directory. Do I have to move that texture (which is a jpeg) I downloaded to the Poser directory? I'm using Poser 6 in case that makes a difference. Thanks for your help, James
