Attached Link: http://www.poserpros.com
Tu devrais aller poser ta question au forum franis de Poserpros ( le petit coin d'akin ). Je ne travaille pas sous MAC. Qu'est-ce que tu essaies d'exporter exactement?Dominique Digital Cats Media
This problem may be due to the DivX 5.2.1 codec. This video codec is not fuly Tiger-compatible. We have found that if this codec is installed, the problem that has been described will occur. Removing the DivX 5.component file from the Library:QuickTime folder should cause Poser to work properly. Regards, e frontier Technical Support
Hello, I use Poser6 with Mac bone 10.4 and I do not arrive has to export with the format obj. Indeed a small caster appears it turns without end. I am obliged to force the software has to leave? Y has to you it an answer has this ?. Bonjour , J'utilise Poser6 avec Mac os 10.4 et je n'arrive pas a exporter au format obj. En effet une petite roulette apparait elle tourne sans fin. Je suis obligde forcer le logiciel a quitter ? Y a t'il une ronse a ce proble Merci
