Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
My python page
My ShareCG freebies
Actually, you can do as ockham suggested directly in Poser, by using the grouping tool on the cloth square (See Dr. Geeps tutorials for examples..) I, too, would have started out by using bigger square and cutting out the unwanted bits (it's just the way my mind works..) It'd probably be quicker and easier to start again using that approach..:-)) Cheers, Diolma
![file_301372.jpg](https://live.cdn.renderosity.com/forum/threads/2457369/file_301372.jpg)
Big plane and small planes which showed in the picture. They are connected with each other,after they became plane respectively in the Rhino.After builing Wind Power System,as a result of operation,the small plane will be blown and broken up.Could you tell me which method can make the big plane and the small smalls not to be blown and broken up under the Wind Power System.
