Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 1:47 am)
Where do you get this DMC file?
http://www.runtimedna.com/mod/forum/messages.php?ShowMessage=156768
Which version of Mimic are you using? I've only tested it in Mimic 3, thus far, but I don't think it would have any problems in Mimic 2.
Nothing else should be necessary to make him work with Mimic. He won't work with Mimic's default configuration, of course, since his morphs have different names. Hence, the DMC file.
Using mimic-2 so iguess its not compatible with apollo :-( Darn!! I guess he will have a non speaking role in my movie.
If you have Mimic 2 pro you can make you own fairly simply. If you only have Mimic 2 then you have to wait til someone does a DMC for you. I would but at this point I have no computers at home. When I get a puter back up and running I'll try and whip a DMC using Mimic 2 Pro for ApolloMax. I did test the Mimic 3 and ApolloMax DMC LIttleDragon supplied and that works well. Gotta be the Mimic 2/3 problem.
HI I have the Mimic DMC file for Apollo Max from "little Dragon" I use it and Apollo's Cr2 in the session manager but when I apply the mimic animation pose file I only get head and eye gestures but no lip movements. are there any other hacks etc to his Cr2 required for mimic lip synching?? thanks.
My website
