Mon, Feb 10, 11:44 AM CST
Subject: It is a question of creating bone.
Aioria ( ) posted Wed, 09 November 2005 at 6:01 AM ยท edited Mon, 10 February 2025 at 11:40 AM
After I imported a cylinder in the Poser I got into the Setup Room,then I used the P4 bikini bottom to get into the Cloth Room.There is a promote likes that:This figure contains polygons which are not grouped to be long to 2 bone.Are you sure you want to leave the Setup Room? By the way,why the font size of my Poser's promote is too small,how can I adjust it?
xantor ( ) posted Wed, 09 November 2005 at 2:26 PM
You need to check that all the polygons are attached to bones, sometimes only one small hard to see polygon is not attached and brings up this error.
Aioria ( ) posted Wed, 09 November 2005 at 6:39 PM
How to check that all the polygons? why the font size of my Poser's promote is too small?
xantor ( ) posted Wed, 09 November 2005 at 9:01 PM
If you look at the object in wireframe mode, it is usually easier to see the stray polygons.
Aioria ( ) posted Thu, 10 November 2005 at 1:55 AM
The image is used in wireframe mode.But the promote is all the same.
xantor ( ) posted Thu, 10 November 2005 at 1:23 PM
No, you switch on the wireframe mode and then use the grouping tool to see which polygons are not in a group.
Aioria ( ) posted Fri, 11 November 2005 at 7:42 PM
Thank you.I get it.
