We just had a discussion about 2). Have they actually fixed the randomized 'trackingScale' issue with TargetGeom? Have they fixed it generally? That would be a nice move forward. :)
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
Seems fine. I loaded the cr2 and the values in Poser matched the cr2. No randomizing.
Not sure what you mean by "generally". When I put (actual deltas), I meant that Master erc dials without deltas weren't ever randomized before, just actual morph dial sensitivity.
Message edited on: 11/11/2005 01:24
-Anton, creator of Apollo Maximus
"Conviction without truth is denial; Denial in the
face of truth is concealment."
And also, Poser now remembers file locations and if you import an obj file as morph, the name of the obj is already there as name of the morph. A lot of small fixes but thay make life a little bit easier.
Ulli
Little Dragon, the preview setting for transparency display was the only fix that interested me... seems I'll have to wait. ;o( BUT I found out, quite by accident, that if you save your project as a pz3/pzz, when you open it again, the transparent objects show up in the document window if you saved it with texture shade view. This is not new with SR2, I found that out before I installed SR2.
France, Proud Owner of
KCTC Freebies
If only they'd fixed the artifacts in the fresnel node, or at least added a ray bias parameter to it so you could fix the problem yourself :-(
View Ajax's Gallery - View
Ajax's Freestuff - View
Ajax's Store -
Send Ajax a message
I'd rather have updates regularly than waiting two or three quarters between updates. I am sure their "to-do" list isn't finished yet.
I think we should make sure they are morally supported and not discouraged. We need them enthuised
Message edited on: 11/11/2005 06:21
I'm with Little Dragon. That Figure Circle bug gave me conniptions. Glad to see it's been stomped. Haven't delved into the others yet but so far the renders seem a tad faster.
In regards to Tranparancy Display ....
I was referring to the preview engine's transparency display setting in render options. At launch, it always defaults to 90%, instead of retaining my preferred setting of "Actual".
Oh, I agree. So far, I haven't found anything new broken by this update. Good work!
The Translate channel as pointed out by lesbentley in this thread. Message edited on: 11/11/2005 11:29
off.
-- Bjarne
Stroustrup
Attached Link: http://ockhamsbungalow.com/Python/SaveMagMorphs2.zip
One nice addition to Python: it's FINALLY possible to set up a full-body morph through Python. I've modified my Mag-to-Morph script to take advantage of this change.My python page
My ShareCG freebies
I know some of you are going to look sideways at me as if to say "that is what you are excited about?!?", but I am thrilled about three issues I asked be fixed.
-Firefly gagging on fragmented obj files(people should still use Spanki's Stomp to reduce file sizes)
-TargetGeom dials (with actual Delta's) having sensitivity randomized upon cr2 load
-Magnet base being replaced with instance of any obj already imported with the nane "Base"
Thankie!
Message edited on: 11/11/2005 00:19
"Conviction without truth is denial; Denial in the face of truth is concealment."
Over 100,000 Downloads....
