Thu, Jan 9, 4:54 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 09 3:46 am)
Subject: Woot! Thanks e-frontier! 3 Favorite fixes
byAnton ( ) posted Fri, 11 November 2005 at 12:16 AM · edited Thu, 26 December 2024 at 1:45 AM
I know some of you are going to look sideways at me as if to say "that is what you are excited about?!?", but I am thrilled about three issues I asked be fixed.
  1. -Firefly gagging on fragmented obj files(people should still use Spanki's Stomp to reduce file sizes)
  2. -TargetGeom dials (with actual Delta's) having sensitivity randomized upon cr2 load
  3. -Magnet base being replaced with instance of any obj already imported with the nane "Base"
Thankie!
Message edited on: 11/11/2005 00:19
-Anton, creator of Apollo Maximus
"Conviction without truth is denial; Denial in the face of truth is concealment."
Over 100,000 Downloads....
kuroyume0161 ( ) posted Fri, 11 November 2005 at 12:48 AM
We just had a discussion about 2). Have they actually fixed the randomized 'trackingScale' issue with TargetGeom? Have they fixed it generally? That would be a nice move forward. :)
 -- Bjarne Stroustrup
byAnton ( ) posted Fri, 11 November 2005 at 1:23 AM · edited Fri, 11 November 2005 at 1:24 AM
Seems fine. I loaded the cr2 and the values in Poser matched the cr2. No randomizing.
Not sure what you mean by "generally". When I put (actual deltas), I meant that Master erc dials without deltas weren't ever randomized before, just actual morph dial sensitivity.
Message edited on: 11/11/2005 01:24
Jules53757 ( ) posted Fri, 11 November 2005 at 1:59 AM
And also, Poser now remembers file locations and if you import an obj file as morph, the name of the obj is already there as name of the morph. A lot of small fixes but thay make life a little bit easier.
Ulli
kyraia ( ) posted Fri, 11 November 2005 at 3:10 AM
But my favourite is still missing: glowing material like in Vue :-(
Little_Dragon ( ) posted Fri, 11 November 2005 at 4:50 AM
My favourite is the fix for the figure circle. The setting is actually remembered now, and I don't need to switch it off manually every time I launch Poser. Now, if they'd only fixed the preview setting for transparency display ....
Francemi ( ) posted Fri, 11 November 2005 at 5:10 AM
Little Dragon, the preview setting for transparency display was the only fix that interested me... seems I'll have to wait. ;o( BUT I found out, quite by accident, that if you save your project as a pz3/pzz, when you open it again, the transparent objects show up in the document window if you saved it with texture shade view. This is not new with SR2, I found that out before I installed SR2.
France, Proud Owner of
KCTC Freebies
Ajax ( ) posted Fri, 11 November 2005 at 6:06 AM
If only they'd fixed the artifacts in the fresnel node, or at least added a ray bias parameter to it so you could fix the problem yourself :-(
View Ajax's Gallery - View Ajax's Freestuff - View Ajax's Store - Send Ajax a message
byAnton ( ) posted Fri, 11 November 2005 at 6:11 AM · edited Fri, 11 November 2005 at 6:21 AM
I'd rather have updates regularly than waiting two or three quarters between updates. I am sure their "to-do" list isn't finished yet.
I think we should make sure they are morally supported and not discouraged. We need them enthuised
Message edited on: 11/11/2005 06:21
SamTherapy ( ) posted Fri, 11 November 2005 at 8:33 AM
I'm with Little Dragon. That Figure Circle bug gave me conniptions. Glad to see it's been stomped. Haven't delved into the others yet but so far the renders seem a tad faster.
Little_Dragon ( ) posted Fri, 11 November 2005 at 9:33 AM
In regards to Tranparancy Display ....
I was referring to the preview engine's transparency display setting in render options. At launch, it always defaults to 90%, instead of retaining my preferred setting of "Actual".
Oh, I agree. So far, I haven't found anything new broken by this update. Good work!
kuroyume0161 ( ) posted Fri, 11 November 2005 at 11:28 AM · edited Fri, 11 November 2005 at 11:29 AM
The Translate channel as pointed out by lesbentley in this thread. Message edited on: 11/11/2005 11:29
ockham ( ) posted Fri, 11 November 2005 at 12:50 PM
Attached Link: http://ockhamsbungalow.com/Python/SaveMagMorphs2.zip
One nice addition to Python: it's FINALLY possible to set up a full-body morph through Python. I've modified my Mag-to-Morph script to take advantage of this change.
My python page
My ShareCG freebies
cedarwolf ( ) posted Fri, 11 November 2005 at 1:22 PM
Mmm...is this a P6 thread? Sounds like P5 problems, too.
maclean ( ) posted Fri, 11 November 2005 at 3:05 PM
Yep, that danged Figure Circle was a nightmare. And it only affected some people. A lot of folks thought I was crazy. 'Just switch it off and save your preferred state' they'd say. Yeah, right.... mac
byAnton ( ) posted Fri, 11 November 2005 at 7:13 PM
kuroyume0161, I am not sure if they fixed Translate. the readme just said TargetGeom.
