Mon, Jan 13, 3:18 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: Best settings for rendering a nude male figure
tankred ( ) posted Sat, 12 November 2005 at 2:33 PM ยท edited Wed, 25 December 2024 at 7:50 AM
I am trying to find the best settings in Firefly that would render the best. I have all of Jepe's bodyhair textures and when I try to render them the body hair does not have that soft look to it. Here are the settings that is suggested by Jepe: Smooth Polygons: Checked Raytracing: Checked Use Displacement Maps: Checked Texture Filtering: UN-checked Set min. bounds to 1 Max texture res 4096 pixels Should I have to worry about the Post Filter Size and Type? Can you set the Max Testure Res. to higher than 4096? Any help will be appreciated! Tankred
Starkdog ( ) posted Sat, 12 November 2005 at 3:36 PM
Hmmm, what lighting setup are you using? Are you using any skin shaders or AO, or IBL? Anyways, it sounds like the lighting might be creating a harsh effect on the hairs. Unfortunately, i don't have any of Jepe's characters, so I can't troubleshoot the problem directly. I hope this helps? -Starkdog
tankred ( ) posted Sat, 12 November 2005 at 3:43 PM
I have the Unimesh Realism Kit and I play around with the lights. I tend to use preset lights from HyperReal and Syd Ravens lights that she did for ApolloMax. Any help? Tankred
