Tue, Feb 4, 9:06 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: How do I create a Alpha mask in Carrara?
DigitalDream#3 ( ) posted Fri, 09 March 2001 at 3:41 PM · edited Tue, 04 February 2025 at 5:28 AM
How do I create a Alpha mask in Carrara? No matter what output option I try, I can't seem to get the mask buffer from being grayed out.I need to do a mask for post rendering. Thanx in advance
litst ( ) posted Fri, 09 March 2001 at 3:52 PM
Did you try to render in Photoshop 2.5 format ? It works with me . litst
DigitalDream#3 ( ) posted Fri, 09 March 2001 at 4:05 PM
Not on this end.Are there any certain settings to get it to be allowed to be selected in the render room or elsewhere? This has me really perplexed.
litst ( ) posted Fri, 09 March 2001 at 4:17 PM
Well, see if it works : create a new scene, go to the render room and change the output file format to Photoshop 2.5 or Photopaint or GIF or Targa or TIFF With those formats, i can check the mask in the G-buffers . Can you ? Are you on PC or Mac ? litst
DigitalDream#3 ( ) posted Fri, 09 March 2001 at 4:31 PM
I'm on a Mac. Nope no can do. The only time I get the option is in a Photoshop 2.5 sequenced image, not a single frame mode.(Which is what I need)
litst ( ) posted Fri, 09 March 2001 at 4:38 PM
That's strange ... Sorry, i'm on PC so i won't be of any help . I assume you have the patched version ? litst
DigitalDream#3 ( ) posted Fri, 09 March 2001 at 4:48 PM
Yup!
MarkBremmer ( ) posted Fri, 09 March 2001 at 5:39 PM
Here is how to engage the Alpha Mask on a Mac: (Antoine said that this was one of the stupidest bugs in Carrara) Render Room>File format>select the "movie" radio button>from the file format pull down menu, select "Sequenced Photoshop 2.5">open G-Buffer section At this point all of the options should be available including Mask. Once selected, you can go back and change the file format options to what you want and the Mask G-Buffer will remain selected. Mark
MarkBremmer ( ) posted Fri, 09 March 2001 at 5:45 PM
Just in case my rambling were unclear.
DigitalDream#3 ( ) posted Fri, 09 March 2001 at 6:28 PM
That did the trick! Thanks!
Hokusai ( ) posted Sat, 10 March 2001 at 9:37 AM
On this note any way to make obects with transparencies cast shadows correctly? When I do it the transparent part of the object casts full shadows, I coudl turn of shadows but hen teh obaque parts do not cast shadows. Another dumb bug
litst ( ) posted Sat, 10 March 2001 at 10:22 AM
Hi Hokusai, To make transparent objects cast shadows correctly, don't forget to enable "light through transparency" in the render options . Also, it doesn't work with soft shadows :( . Hope this helps ! litst
