Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Here is how to engage the Alpha Mask on a Mac: (Antoine said that this was one of the stupidest bugs in Carrara) Render Room>File format>select the "movie" radio button>from the file format pull down menu, select "Sequenced Photoshop 2.5">open G-Buffer section At this point all of the options should be available including Mask. Once selected, you can go back and change the file format options to what you want and the Mask G-Buffer will remain selected. Mark
How do I create a Alpha mask in Carrara? No matter what output option I try, I can't seem to get the mask buffer from being grayed out.I need to do a mask for post rendering. Thanx in advance
