Mon, Jan 27, 10:11 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 5:49 pm)
Subject: Problem loading a figure
clarkking ( ) posted Thu, 17 November 2005 at 10:42 PM · edited Mon, 27 January 2025 at 10:10 PM
All of the sudden when I try to add V3 to a new scene only the leg loads (one of them). I have everything set to show. I have already unistalled V3 and reinstalled once already. That did fix the problem but then it happened again for some reason. Has anyone heard of this occuring, do you know why and of course how can I fix this? Thank you for any advice you can give. C
Acadia ( ) posted Thu, 17 November 2005 at 10:46 PM
Maybe it's a memory issue? Poser is a memory hog and it does some pretty weird things on me when it's running low on memory. Does it ever do it after a reboot or is it after you've been in Poser for awhile?
clarkking ( ) posted Thu, 17 November 2005 at 10:52 PM
No it actually (as far as I can determine) only happen after I have saved a scene with a particular character set that i have received error regarding binary morph data (i'm not sure what that means yet but) it's those scenes that the figure is being saved. then let's say I close that file when I go directly to v3 only the leg appears. I should be okay on resources. C
Jules53757 ( ) posted Fri, 18 November 2005 at 2:02 AM
Switch off external Binaries
Ulli
EnglishBob ( ) posted Fri, 18 November 2005 at 3:29 AM
What version of Poser is this? If it's Poser 4 / Poser Artist, try deleting ...RuntimeGeometriesDAZPeopleblMilWom_v3.rsr which can become corrupted. Poser will generate a new one next time you load the figure, so it will take a little longer that first time.
fetter ( ) posted Fri, 18 November 2005 at 5:53 PM · edited Fri, 18 November 2005 at 5:55 PM
And then remember to set the new .rsr file attribute to "read only", or it will be re-corrupted every time you save the file.
Chewed many square feet of carpet over this until someone clued me in.
Message edited on: 11/18/2005 17:55
clarkking ( ) posted Fri, 18 November 2005 at 7:15 PM
It's P6, okay so silly question but how do i switch off external binaries? The problem did fix itself once I unistalled v3 and re installed. but everytime i use this particular charac., set this happens. Why? Thank you, C
Jules53757 ( ) posted Sat, 19 November 2005 at 4:14 AM
Under edit:general preferences:misc you'll find Save files
Ulli
