Fri, Dec 27, 2:12 PM CST
Photography F.A.Q (Last Updated: 2024 Nov 26 6:56 am)
Subject: Working in B & W (Last of Winter)
billglaw ( ) posted Fri, 09 March 2001 at 10:07 PM ยท edited Thu, 26 December 2024 at 9:50 PM
Learning to use a Nikon 880 takes a degree of persistance. Cropped and a small change in intensity. The use of the B & W option gives a tight pixel resolution. You can copy the old masters technique if you choose. Regards, Bill
Syyd ( ) posted Sat, 10 March 2001 at 8:39 AM
Nice picture, thank you for sharing.....could you also share your masters techniques? I use the 880 and one of the things I find the most difficult is getting used to such a small camera, and camera shake. The possibilities however, are endless.
billglaw ( ) posted Sat, 10 March 2001 at 5:57 PM
My favorite camera for several years in the 1950's was a 4x5 format Bush Pressman. With a 127mm wide angle lens. You could read negatives directly. ASA 50 film and lots of light. We have come a long way. On subject of camera shake. I have considered buying an inexpensive painters tool for roller extention. Making an adapter that would be placed on the camera. The result is a short (36/72 in.)telescoping monopod. Very light and aids the stability. It would be quick on/off and if lost easily replaced at any hardware. I'll send some pictures of vise-grip tools adapated for camera mounting. Regards, Bill
